  4. 3rd piston ring please help
32 Posts 4 Posters 6.7k Views
    Something isn't right if you are losing compression mate.
    Are you sure this is what is happening?
    @calum not at all I've got it down to either fueling under load or weak spark under load as on the garden it's okay but if I take it out and select 2nd the bike comes to a stop at the end of the gear then after that it starts running weird like a splutter withough the noise if you know what I mean then I have to push it as it won't ride at all but will still run and rev
    ZrakoZ 1 Reply Last reply
      ZrakoZ
      ZrakoZ
      Zrako
      @declan well , is your clutch set up properly? I mean the tension .
      1979 Jawa Mustang 50
      2003 Gilera DNA 125 R.I.P
      2015 Keeway TX 125 SM
      2006 Yamaha DT 125 X
      • ZrakoZ Zrako
        @zrako yeah, if it's losing power under load then it sounds like clutch is slipping.
          @calum the clutch was in a bad state but since I got a new lever and adjuster it will pop the front wheel up but it's losing the power after initially using the clutch it feels good but after then it's losing power I don't believe it to be the clutch but I really thought it was till I got a new lever the other day before that I could redline drop the clutch and barely move
            ZrakoZ
            ZrakoZ
            Zrako
            @declan is there plenty of free play on the lever?
            • ZrakoZ Zrako
              @zrako yes mate
                Yeah but the load on the clutch in 1st is going to be minimal.
                  @calum so what would you lean to will bad plates have this effect?
                    @declan Wouldn't be a bad place to start.
                    An idea would be to see if it pulls fine with no load on the engine.
                    So first just put the bike on a paddock, start it and go through all the gears. If that works no problems then jump on bike and od the same but keep it part throttle only. No load.
                      @calum I've tried it with no load it works pretty much as it should
                        @declan With load on the engine does it revs hard and no power. Clutch is slipping then.
                        Either adjust it or replace it.
                          @calum no it lacks power off the line when moving its decent shift into 3rd the revs die down to a slow idle and you go about 3mph
                          CalumC 2 Replies Last reply
                            @declan Nah doesn't sound like clutch then.
                            Sounds like it's a carb setting.
                            Take the plug out and have a look.
                            Could simply just not getting enough fuel.
                              @calum that's what I'm thinking as after I try hit 3rd and stop it feels starved not revving clean and real slow idle but sorts it's self out after a rest I've been doing some tests as it's got an open filter not the box as I have no rubber or filter for the air box but I haven noticed anything by restricting air flow
                                @declan Sounds like fueling to me mate.
                                  @calum I'll pick up a new carb and see how it goes thank you
                                    @declan Just sort heone you got outmate.
                                      @calum ive been through it more times I can count and never found any issues it's spotless and as for the settings I wouldn't have a clue I'm guess it's way lean on the a:f screw but it turns off on command when hot using the choke
                                        Sounds rich to me. Lean would cause a high hanging idle. The bike should still rev out, just without much power.
                                        When rich, everything is sluggish, and going WOT can feel like youre hitting a rev limiter, or as if the bike has a restriction.
                                        Have you done all the basics? Fresh plug and clean airfilter? Is your floathight correct?
                                        • J Jens Eskildsen
                                          @jens-eskildsen that's a no on the float I've never really done that unless I really need to and if it's rich what do you reccomend a:f screw for move the float pin? Plug is good and filter is good no air leaks
