  4. 3rd piston ring please help
32 Posts 4 Posters 6.7k Views
    @declan Nah doesn't sound like clutch then.
    Sounds like it's a carb setting.
    Take the plug out and have a look.
    Could simply just not getting enough fuel.
    @calum that's what I'm thinking as after I try hit 3rd and stop it feels starved not revving clean and real slow idle but sorts it's self out after a rest I've been doing some tests as it's got an open filter not the box as I have no rubber or filter for the air box but I haven noticed anything by restricting air flow
      @calum no it lacks power off the line when moving its decent shift into 3rd the revs die down to a slow idle and you go about 3mph
      @declan Sounds like fueling to me mate.
        @calum I'll pick up a new carb and see how it goes thank you
          @declan Just sort heone you got outmate.
            @calum ive been through it more times I can count and never found any issues it's spotless and as for the settings I wouldn't have a clue I'm guess it's way lean on the a:f screw but it turns off on command when hot using the choke
              Sounds rich to me. Lean would cause a high hanging idle. The bike should still rev out, just without much power.
              When rich, everything is sluggish, and going WOT can feel like youre hitting a rev limiter, or as if the bike has a restriction.
              Have you done all the basics? Fresh plug and clean airfilter? Is your floathight correct?
              • J Jens Eskildsen
                @jens-eskildsen that's a no on the float I've never really done that unless I really need to and if it's rich what do you reccomend a:f screw for move the float pin? Plug is good and filter is good no air leaks
                  You could remove the side of the airbox and do a testrun and see if its better or worse.
                  Dont think you can adjust the airscrew enough to sort this out.
                  • J Jens Eskildsen
                    @jens-eskildsen I have an open filter cone style
                      Whoa, that opens up another can of worms...
                      • J Jens Eskildsen
                        @jens-eskildsen that's why I said I was trying to restrict air flow but made no difference
                          It's getting difficult.
                          When you start modifying stuff you're making it harder to diagnose the problem.
                          You really should only be modifying stuff when you know what you're doing.
                          If you're stuck, then I would revert it all back to stock and take it from there.
                            @calum that's the problem I haven't done this mod I got the bike with no filter assembly
                              @declan Yeah, like I said. Get it all back to exactly how it should be. Then we can help to diagnose the fault.
                              It might be overshadowed by one of the many mods that have been done to the bike, hence why we are all struggling to come up with a single solution.
                              Or learn how jetting works. There is plenty of guidance on this forum for said information.
