  4. Sump plug washer
Sump plug washer
9 Posts 5 Posters 1.6k Views
  • D
    dan28
    Can the oil drain bolt / sump plug washer be reused
    If not then what size is the washer I don't want to remove the old until I have a replacement will probably have one at work if some one can tell me the diameter of the an size of the washer
      It's a copper washer and usually they cannot, however I always did.
      • F
        F
        I got away with one reuse. Ended up buying a selection set off Amazon, as all 3 of my bikes have multiple sealing washers in different sizes so cheaper in the long run.
        • D
          dan28
          What size is the thread m 6. ?
          • ZrakoZ
            ZrakoZ
            Zrako
            https://www.ajsutton.co.uk/genuineparts/9058/10/yamaha-dt125x-2006/crankcase-cover-1?uid=0
            Items 22 and 23
            1979 Jawa Mustang 50
            2003 Gilera DNA 125 R.I.P
            2015 Keeway TX 125 SM
            2006 Yamaha DT 125 X
              M8 oil drainage bolt.
                NottsbikerN
                NottsbikerN
                @calum said in Sump plug washer:
                If you don't have 2p for a new washer or the shops shut you can anneal copper to make it soft again to use as if new. Google the process if interested or skint 😉
                • NottsbikerN Nottsbiker
                  @nottsbiker Pretty sure I just didn't know it was supposed to be reused.
                  Explains why my car is leaking gearbox oil FFS!
                  Definitely need to sort that out
                  • NottsbikerN
                    NottsbikerN
                    I'd fit a new one but its handy to do on the old gas cooker if you are working on the bike at night or on a Sunday etc
