  3. Framework
  4. Replace chain roller?
27 Posts 3 Posters 7.2k Views
  • Irongamer727I
    Irongamer727I
    The heavily worn roller is the one on the underside of the chain, and the other is the one sitting higher up.
    First off, could someone tell me what "the other" does? Is it for when the suspension is compressed to max after a high jump? It looks brand new!
    Secondly, is it worth just changing the worn one with "the other"?
    Or should I order a new set?
      Pretty sure you an just replace them with like penny board wheels. I'm sure i've seen that somewhere.
        Irongamer727I
        Irongamer727I
        @calum how important are they? Seems to be quite hard to get hold of new
          Fairly important if you find your chain slackens
          • Irongamer727I
            Irongamer727I
            https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253416913017
            These must fit right?
              Yeah I guess, pricey though!
                Irongamer727I
                Irongamer727I
                @calum really? Seems to be genuine. Can't get them much cheaper from what I can find.
                • Irongamer727I Irongamer727
                  @irongamer727 https://www.ebay.co.uk/itm/8mm-Chain-Roller-Slider-Tensioner-Wheel-Guide-For-50cc-110cc-Pit-Dirt-Motor-Bike/323087618771?epid=2286281917&hash=item4b3985d2d3:g:jT0AAOSwdLVai9oi
                  Just go for something like that.
                    Irongamer727I
                    Irongamer727I
                    @calum were the rollers from the Yamaha factory "grooved" like the one you linked or straight like the one I linked? Perhaps my existing isn't in desperate need if replacing.
                      @irongamer727 No, the OEM ones are flat.
                      But I dunno, seems a lot for some chain rollers if you ask me.
                        Irongamer727I
                        Irongamer727I
                        @calum I agree.
                        • Irongamer727I
                          Irongamer727I
                          Good news! Found flat chain rollers in a local shop nearby. Will get them for sure. So much nicer than having to wait until April 20th if I ordered from eBay.
                            @irongamer727 the chain wears the roller to fit the chain perfectly
                            • Irongamer727I
                              Irongamer727I
                              What do you think about making a chain roller from wood? Stupid idea?
                                @irongamer727 yeah that’s pretty stupid dude 😉 why would you want to do that they’re only a few pounds and the wood would rot chip splinter and just not function properly I really don’t see an upside to using wood unless you do?
                                  Irongamer727I
                                  Irongamer727I
                                  @declan it's harder than it seems to get a decent chain roller that doesn't include 3 weeks shipping.
                                    @irongamer727 it really isn’t bud or atleast I don’t think so do you know the size of your roller the bearing size IE 12mm?
                                      Irongamer727I
                                      Irongamer727I
                                      @declan 12mm inner diameter, 35 outer and 25 28mm wide.
                                        @irongamer727 your right lol- https://m.ebay.co.uk/itm/Black-Adjuster-Chain-Tensioner-Bolt-On-Roller-Motorcycle-Chopper-ATV-Pit-Bike-UK/162473785599?hash=item25d43138ff:g:kHEAAOSwmgJY8EP2
                                        The best compromise I can find on ebay
                                        Irongamer727I CalumC 2 Replies Last reply
                                          Irongamer727I
                                          Irongamer727I
                                          @declan and at that price I might as well buy OEM. Thinking about fabricating myself.
                                          declanD 2 Replies Last reply
