  3. Carburetor
  4. Dt125 mikuni carb
Dt125 mikuni carb
37 Posts 4 Posters 11.4k Views
    Ask any tuner how to set up a carburettor and you'll get the same response.
    It depends on your setup.
    Everything from Atmospheric conditions to state of the engine and even altitude will affect jetting.
    It's imperative that ones carb is tuned to these varying conditions.
    20 years ago, Yamaha spent thousands on designing the perfect carburettor settings to get the DT roughly in the right ball park.
    The moment you started modifying the bike, you throw all of Yamaha's hard work out the window.
    Just because it had some ridiculous settings on it, doesn't necessarily mean it was wrong.
    Jetting should be done to suit, and there is reams of guides on here to help you get the bike in right area.
    Irongamer727I
    Irongamer727I
    @calum guess so. Only way is to buy and try stuff I guess
    • Irongamer727I Irongamer727
      Response please...
      K
      K
      kevin
      @irongamer727 I’m a firm believer in leaving things the way they are and not thinking I’m better than the designers.
      To answer your question 35 is very big for your carb.
      Does Athena give any tips on resetting.
      You say it’s hard to start, have you checked the fuel feed pipe when the cold start lever is on as it’s very narrow and often gets blocked.
      • K kevin
        Irongamer727I
        Irongamer727I
        @kevin nope. Athena don't give any recommendations at all. Do you mean the fuel hose itself? That's brand new. The choke works, could there be some debris in the mechanism you think?
        K 1 Reply Last reply
          K
          K
          kevin
          @irongamer727 thin brass pipe near to the hole the pilot jet drops in is the fuel pipe whilst on the choke cycle, very thin wire needs poking down to the bottom and then through the cross holes.
          • Irongamer727I
            Irongamer727I
            Alright so as I'm getting progressively better at them wheelies and can ride longer, I've noticed stuff. The carb wants to piss out the transparent liquid gold (petrol).
            Is tilting the carb the only way to go? Or could a float adjustment do the trick?
              @irongamer727 Sounds like the flat is causing you issues.
                Irongamer727I
                Irongamer727I
                @calum the flat?
                  @calum the flat?
                  @irongamer727 Float sorry.
                    Irongamer727I
                    Irongamer727I
                    @calum would I want to raise or lower it?
                      @irongamer727 Just make sure it's shutting off the fuel bud
                        Irongamer727I
                        Irongamer727I
                        wrote on last edited by Irongamer727
                        #31
                        @calum won't that affect my crusing, regular riding?
                        I mean the carb will tilt almost 90° on a real wheelie.
                        I've spoken to some guys really good at that rear wheel (they ride a dt) and some of them just plug the overflow. But I mean it's clearly leaking for a reason. Can't understand how plugging the owerflow works.
                        • Glynn123G
                          Glynn123G
                          Glynn123
                          As far as I'm aware if you plug the overflow it will still dump the fuel, but it will dump it out the rear intake of the carb into the airbox, which will then get sucked into the engine. Never had or seen any problems with standard Dt carb during wheelies, and I know people who regularly scrape and coast.
                          • Glynn123G Glynn123
                            Irongamer727I
                            Irongamer727I
                            @glynn123 someone's got to be the first😛🔫
                            Glynn123G 1 Reply Last reply
                              Glynn123G
                              Glynn123G
                              Glynn123
                              @irongamer727 doesn't seem like you're having much luck with this build mate haha
                                Plug the overflow lol, that's just masking the problem.
                                It'd be overflowing for a reason and the float is a pretty well balanced item, meaning it shouldn't just purely on gravity. You'd have the be upside down for it to shut, at which point you won't be needing any fuel.
                                I'm not saying adjust it, I'm just saying make sure it does shut off the fuel.
                                  Irongamer727I
                                  Irongamer727I
                                  @glynn123 Hehe I mean I'm learning stuff at least, the engine is healthy and all but I guess some things should just not be this hard.😛
                                    Irongamer727I
                                    Irongamer727I
                                    @calum
                                    I should just be able to tilt the carb ~80 ° and just make sure it closes then. Hopefully a quick fix.
