  4. DT200WR restoration project pic heavy
272 Posts 17 Posters 162.1k Views 5 Watching
  • Louis-DT-WRL Louis-DT-WR
    @Glynn123 do you have a picture of the front wheel?
    Is the tire on it?
    Glynn123G
    Glynn123G
    Glynn123
    @Louis-James yeah there's some dualsport tyre on it right now, I'll try get a picture when I finish work in the morning, should get back to you sometime over the weekend if not though
    • Glynn123G Glynn123
      Louis-DT-WRL
      Louis-DT-WRL
      Louis-DT-WR
      @Glynn123 ok thanks.
      Would you prefer to sell the whole set up? Or do you want the tyre?
      Glynn123G 1 Reply Last reply
        Glynn123G
        Glynn123G
        Glynn123
        @Louis-James I'd be happy to sell the whole lot if you wanted, I have no use for the tyre as my DT is just in sm trim and should be staying that way
          Louis-DT-WRL
          Louis-DT-WRL
          Louis-DT-WR
          @Glynn123 did you fit wr200 forks?
          Just after the front wheel tbh.
          Thanks
            Thanks
            Glynn123G
            Glynn123G
            Glynn123
            wrote on last edited by Glynn123
            #165
            @Louis-James I fit WR 426 forks but made my own custom axle to run the standard DTR/WR200 front hub sizes, the WR200 front disc was the same size as a standard nissin front brake system on a WR 426 so was a better wheel choice than changing calipers to use the smaller DTR wheel and disc combo
            Louis-DT-WRL 2 Replies Last reply
              Louis-DT-WRL
              Louis-DT-WRL
              Louis-DT-WR
              @Glynn123 great thanks
                Louis-DT-WRL
                Louis-DT-WRL
                Louis-DT-WR
                @Glynn123 the front wheel I have looks exactly like a wr400 or wr426.
                  Glynn123G
                  Glynn123G
                  Glynn123
                  @Louis-James the axle is larger in the 400/426, the WR 200 wheels I bought use the same size axle as a DT, I actually ran them with the DT spacers on my standard forks for a while. Is this the same with yours?
                  Louis-DT-WRL NottsbikerN 2 Replies Last reply
                    Louis-DT-WRL
                    Louis-DT-WRL
                    Louis-DT-WR
                    @Glynn123 I haven't tried them on yet. But you could use bearings with small ID?
                      NottsbikerN
                      NottsbikerN
                      @Glynn123 according to the All Ball's site the 400 front end fits straight onto the 200. Guessing it wasn't as easy as that for the 125?
                      • NottsbikerN Nottsbiker
                        Glynn123G
                        Glynn123G
                        Glynn123
                        @Nottsbiker are you referring to the front wheel or fork assembly mate?
                        • NottsbikerN
                          NottsbikerN
                          Sorry - meant to say the 400 front end complete - yokes / forks etc
                            Glynn123G
                            Glynn123G
                            Glynn123
                            #173
                            @Nottsbiker the yokes use a different bearing type on the top, and bottoms different taper too. Standard DT 125 uses ball bearings on the top compared to tapered rollers, also 400 stem is longer, takes some spacer work and a bearing cup but the swaps doable if you have a lathe.
                              NottsbikerN
                              NottsbikerN
                              @Glynn123 thanks. Makes me realise I'll be building supermoto rims onto my hubs and looking for an oversized disk to make the changes. I have access to cnc etc but will try to minimise this type of work to just a caliper bracket
                                NottsbikerN
                                NottsbikerN
                                @Louis-James few quick questions if you don't mind;
                                Front fork guards - assuming you've gone with UFO YZ new old stock?
                                What size is the bottom bolt on the forks that hold them together? It's massive and I need to buy the correct one
                                Is the chainguard the same as a 125?
                                Is the gear lever the same as a 125?
                                Where did you get your chain slider without taking out a new mortgage?
                                I've got a factory manual in Japanese but no parts list - do you have one at all you could email across?
                                Cheers - Ben
                                  Cheers - Ben
                                  Louis-DT-WRL
                                  Louis-DT-WRL
                                  Louis-DT-WR
                                  @Nottsbiker said in DT200WR restoration project pic heavy:
                                  Cheers - Ben
                                  Hi Ben,
                                  Yes the fork guards are old stock yz ones around £28
                                  On the forks, are you regarding the one under the bottom of the fork leg?
                                  I used a cheap AliExpress chain guard for the dt125r
                                  The gear lever is the same.
                                  The chain slide I bit the bullet and bought one from Yamaha... £45
                                    Cheers - Ben
                                    Hi Ben,
                                    NottsbikerN
                                    NottsbikerN
                                    @Louis-James nice one mate
                                    Did your fork guards come with the clamp / guide parts? Mine are yellow and broken
                                    The fork bolt is the bottom one as I need to fit some new seals as mine are leaking. They've taken out the pads too ffs!
                                    Ben
                                      Ben
                                      Louis-DT-WRL
                                      Louis-DT-WRL
                                      Louis-DT-WR
                                      @Nottsbiker yes they came with the clamps.
                                      I don't think it's a standard size bolt but it's probably the copper washer leaking.
                                        NottsbikerN
                                        NottsbikerN
                                        @Louis-James cheers! Btw it's the seals leaking not the bolt o-rings. To change the fork seals I've got to strip the forks completely and the large bolts hold the damper rods in 😉
                                          Louis-DT-WRL
                                          Louis-DT-WRL
                                          Louis-DT-WR
                                          @Nottsbiker mine were leaking on my mates bike.
                                          It's usually because of crap in the seal. There's a trick to fix it.
                                          Pretty much like this: https://youtu.be/-D9ygYuSDiM
                                          You can make similar tools with beer cans or plastic bottles
