  3. Carburetor
  4. Lectron carbs
Lectron carbs
22 Posts 6 Posters 5.8k Views
  • Glynn123G Offline
    Glynn123G Offline
    Glynn123
    Anyone had experience with any of the lectron powerjet carbs? Thinking of upgrading to a 34mm lectron to go with my 3MB barrel once it's ported,
    Additionally what carb sizes have people experimented with on dtrs
      I heard of them, but to be honest with you, just jet a VHSA Carb properly and you'll be laughing.
      • Glynn123G Glynn123
        @Glynn123 from what I’ve seen I think they’re amazing
        • Glynn123G Offline
          Glynn123G Offline
          Glynn123
          What size carb did you use on your RE Calum? Also did you have to fit a bigger intake boot? I've heard an early CR 125 34mm manifold and reeds can fit but I'm not sure.
            @Glynn123 I run the VHSB Carb on the RS, but that's what they had standard.
            The DTR runs a TZR Barrel which ran the VHSA as standard.
            I just modified the DTR inlet to fit, but you can get step down inducers as well.
            • Walney-ReptilesW Offline
              Walney-Reptiles
              Well i contacted lectron and apparently the lectron carbs wont work on the dtrs so where the heck do i get one from?
              • Walney-ReptilesW Walney-Reptiles
                @Walney-Reptiles what about smart carbs?
                Walney-ReptilesW 1 Reply Last reply
                  @Walney-Reptiles wha? Why not. That doesn't sound right.
                    Walney-Reptiles
                    @Calum This is what they said to me via email
                    This is my message
                    Hi there
                    im enquiring about getting a lectron carb for a 2002 yamaha dtr 125 new/made is it possible to get one for this bike? im in the uk i will have to save up for the carb which could take me a few months, is there a pay monthly option for the carb? if you can make one what info will you need from me?
                    They replied with
                    Hi Josh,
                    Thanks for reaching out. Unfortunately, we don’t have a carb option for that model at this time.
                    So i sent this back
                    can the yz125 carb not be tuned for the yamaha dtr 2-stroke 125 engine?
                    They replied with
                    Josh,
                    Thank you for reaching out to us. Sorry, no the yz125 carb will not be able to go on your application.
                    So what lectron carbs are people using on there yamaha dtrs?
                      Walney-Reptiles
                      @declan Never heard of them can you send me a link to one that works on the dtr?
                        @Walney-Reptiles I don’t have any knowledge beyond that I know what they look like
                          Seems more of a linear product take a look, https://www.sip-scootershop.com/EN/Products/618440SC/Carburettor+SMARTCARB+36.aspx?_country=3A6304BB-CC81-4ED5-9F63-1FF45FE1ABFA&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=618440SC&gclid=EAIaIQobChMI3-HFusXb5QIVxdDeCh1EmQzJEAQYAiABEgIZ3fD_BwE
                            What no that's a load of rubbish.
                            It's just a carb, they clearly are not interested in helping you. You can do what you like, I don't know much about the lectron carb but if you are that interested in one just buy it and fit it.
                              Walney-Reptiles
                              @Calum Il go for anycarb as long as it dosnt restrict my bike, if you tell me which one togo for il buy it when i can then if you dont mind can you help me set it up as im not to clued up on setting them up, dont want to burn a hole in my piston if you get what i mean
                              • M Offline
                                M Offline
                                mhbikesnbits
                                Different experience from Lectron when I ask for some information 2747F245-6F07-489B-A53A-024F099B6903.jpeg
                                • M mhbikesnbits
                                  Walney-Reptiles
                                  @mhbikesnbits What did they say to you?
                                  M 1 Reply Last reply
                                    M Offline
                                    M Offline
                                    mhbikesnbits
                                    @Walney-Reptiles it’s on my last post bud messed the screen shot up just updated my last post
                                      It's a carb, I don't see why it wouldn't work. I don't run stock carbs on my bikes.
                                      clawsC 1 Reply Last reply
                                      • M mhbikesnbits
                                        Walney-Reptiles
                                        @mhbikesnbits Just seen it cheers for the info bud did you go for one of these carbs in the end?
                                        • M Offline
                                          M Offline
                                          mhbikesnbits
                                          Not yet bud got to have a think not quite got to the carb stage yet in my build
