  4. Athena 170cc bore kit recommendations
jettingathina 170tuning170bore kit
12 Posts 7 Posters 2.1k Views 1 Watching
  • H Offline
    H Offline
    harveymg
    hi, my names Harvey and am thinking of buying a DT/R/RE/X to tune to 170 with an Athena kit but am unable to find the recommended carb/jetting, downpipe, cdi and sprocket ratios to run with the kit. I do have previous experience with tuning bikes as I have restored and tuned a Yamaha DT50MX.
    Any help would be greatly appreciated
    • Thanks, Harvey
    DartyD 1 Reply Last reply
    • H harveymg
      • Thanks, Harvey
      DartyD Offline
      DartyD Offline
      @harveymg Hi Harvey,
      Firstly, I've never had a 170kit. But have ridden one. I would recommend looking at tuning a 3MB or 4FU barrel and cylinder head rather than spending £450 on the Athena kit.
      I had a tuned TZR 134cc engine with Mikuni TM32 and Ignitech ignition upgrade, and it would pull hard to 85mph in 5th gear, all around the same cost as an Athena Kit alone.
      The port timings on the 170 kit are seriously underwhelming but can be modified properly though,
      My advice, have a gander at tuning the 125. It was a blast, and relatively inexpensive.
      H 1 Reply Last reply
      • DartyD Darty
        H Offline
        H Offline
        harveymg
        @Darty said in Athina 170cc bore kit recommendations:
        Thanks Darty for the responce but im fairly new to the DTR tuning. could you tell me what the difference between the 3MB and 4FU cylinder is. and what jetting you were running on your Mikuni while on that setup
        CalumC NottsbikerN 2 Replies Last reply
        • H harveymg
          @harveymg I concur on @Darty's advice.
          With regards to jetting, bikes should be jetted on a case by case basis. Ones jettings may not be correct for anothers. I'd always recommend jetting your bike to suit, rather than taking someone elses setting.
          • H harveymg
            NottsbikerN Offline
            NottsbikerN Offline
            @harveymg I'd contact Mick Abbey for a quote on the tuning work and see what it would cost that way you'd get it all set up correctly 😉
            • Irongamer727I Offline
              I have had plenty of experience with the Athena 170. Bad quality casting and bad overall performance. There was even a hole in my cylinder which leaked coolant. Athena wouldn't bother. Don't buy if you are looking for performance.
              3
              • DanRacingD Offline
                DanRacingD Offline
                DanRacing
                I'm actually building a fully tuned engine based on the athena 170 cylinder, cylinder must be ported(in my case i've fully done Booster Exhaust ports and intake work aswell as engine case work., and you must be running atleast a 53mm stroker crankshaft to be able to get something out of this kit(i actually have a fully built cnc one for sale right now). You should also add a programable cdi to be able.
                If you need any kind of tuning work hit me up on message for a quote for exactly what you want to do with it.
                Some of the guys are kinda correct here, if you don't want to spend alot of money, just get yourself a 4FU cylinder ported, your cylinder head machined to get the correct squish and combustion area, a decent carburator.
                A good ported 175cc(yes because for it to run correctly you must atleast use a 53mm stroker crank which increases it to 175cc) will make more power and more torque than a good ported original cylinder.
                • DanRacingD DanRacing
                  H Offline
                  H Offline
                  harveymg
                  @DanRacing thanks for the advice I'm probably going to end up doing that as I don't have a very big budget and wouldn't like to to a lot of work like that. I will look into the 4FU cylinder. Where would be a place i could get one of them?
                  DanRacingD 1 Reply Last reply
                  • H harveymg
                    DanRacingD Offline
                    DanRacingD Offline
                    DanRacing
                    @harveymg said in Athina 170cc bore kit recommendations:
                    I might be able to get one here in portugal and port for you then ship it there to the UK. They are common here in Portugal, the 3MB ones are cheaper but they have a iron bore instead of nikasil
                    • Irongamer727I Irongamer727
                      H Offline
                      H Offline
                      harveymg
                      @Irongamer727 that's really bad! im going to take everyone else advice and get a 4FU or 3MB cylinder instead with a aftermarket pipe and carb
                      • B Offline
                        B Offline
                        BEng1968
                        wrote last edited by
                        I think we have a bot
                          wrote last edited by Calum
                          Cheers @beng1968 .
                          I must admit, I bought 2 more Athena kits sometime after this post was made and can't concur with the opinions here.
                          The casting was spot on and it was very good value for money. Considering it comes with everything you'd need to bolt it onto your engine, I'd say it's good value.
                          I will agree it's not YZ rip roaring performance from stock, and considering the extent of tuning on my DTR, it's still nothing compared to a stock Aprilia RS 125.
                          However, it's not without its merits. The extra CCs give a nice broader range of power, which as I've gotten older I've come to appreciate more (I'm no longer 75kgs wet 🤣 ).
                          I did take my cylinder to Mick Abbey for further porting and there is still more porting work that I need to do on my setup. It should be a decent bit of kit, when setup properly.
                          The first experience I had was when I loaned my brothers 2001 DTR back in 2010, he'd fitted the Athena kit amongst various other mods, and that went very well. At the time, I went all in on a ported 3MB00P cylinder from the TZR Belgarda and that setup definitely served me well. I haven't been on my DTR for several years now and I am eager to fire it up again to rejudge my opinion.
