  3. V force reeds dt
V force reeds dt
11 Posts 7 Posters 3.7k Views 1 Watching
  • stinkwheelerS
    stinkwheelerS
    stinkwheeler
    Hi everyone i have acquired another set of dtr v force reeds obviously they are made for somthing else but they seem like a direct perfect fit although they are slightly shorter in to the crankcase ( will post pics in a bit ) but othewise are identical anyone had any experience with them on a dt ?
    The hills are alive with the sound of ... braaaap baaaaap ๐Ÿ˜
    • stinkwheelerS
      stinkwheelerS
      stinkwheeler
      Here is the comparisons between the 2 im unsure as to the reeds being shorter that it wouldn't direct the fuel air mix as well as the standard ones .... although it would let more air fuel mix through as there are more reeds and a bigger flow http://imgur.com/gallery/8feJhqK any thoughts. Many thanks .
      • NottsbikerN
        NottsbikerN
        Think they are shorter because there are x4 sets of petals not x2 as stock
        • B
          B
          BEng1968
          I know this is an old post, but what bike was the V force reed block off?
          • B BEng1968
            @beng1968
            Think it was meant for a Dtr. Just google vforce reeds. Theyโ€™re an aftermarket manufacturer I think...
            • B
              B
              BEng1968
              I have searched for V force reeds for the dt125r but I'm unable to find any, which is why I assumed these were for a different bike.
              B 1 Reply Last reply
              • B BEng1968
                B
                B
                BEng1968
                Looking at the pictures again, you can see the V Force block has been modified, so I doubt these V Force block is originally for a DTR125.
                • B BEng1968
                  markus.wM
                  markus.wM
                  @beng1968 I'm sure I read somewhere that it's the cr125 reedblock.
                  • markus.wM markus.w
                    @markus-w cr ones aren't really big enough the blaster 200 reeds are a better fit
                      dan28
                      @declan pretty sure you can use some intended for yamaha blaster 250 /200 someone did it on here
                      • D dan28
                        @dan28 yeah I did it as I said the blaster 200 are a better fit the cr 125 ones are a little too small but you can make them work
