  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 108.1k Views 3 Watching
    Powdercoating is great for resilience.
    But the finish isn't always the best. For things on show, can't bet 2 pack paint. Fot things that need protecting, powdercoat.
    M Offline
    M Offline
    mhbikesnbits
    @Calum i also like 2pac I spray that a lot where I work probably my second choice if i didn’t go with powder coat also always wanted to try cerakote heard great results with that too
    N 1 Reply Last reply
    • M mhbikesnbits
      #102
      @mhbikesnbits 2k paint is far superior to regular cellulose paint. Pretty much all rattle cans are only 1K cellulose paint. 2K is more durable and also chemical resistant, so it's much more robust and provides a superior finish to protect your parts. If you have a compressor and can mix paint then I'd go for the 2K, use Zinc primer on non-aluminum parts and a self etch primer on Ali parts, for even more protection and longevity. Or if you have a friend or good body shop nearby then get a professional to do it. But like I said think long term and what will be the simplest and cheapest solution if your parts ever need repairing in the future. :winking_face: :winking_face:
      • M Offline
        M Offline
        mhbikesnbits
        Busy life = lack of progress, however have blasted last couple of bits for the engine ready for powder coating and plastics to be rattle canned
        I have vaqua blasted the plastic parts as it leaves a nice key like you would get off shot blasting metal perfect for spraying
        • M Offline
          M Offline
          mhbikesnbits
          Engine parts took to the powder coaters £110 is the cost not too bad in my opinion considering the masking work on it ect, always a top job by my guy - crank case, cylinder + head, clutch cover, power valve cable box power valve cover, water pump and power valve cap, gone for a satin black ral 9005 17% gloss
          • M mhbikesnbits
            @mhbikesnbits That's a good price, I wish the coaters around here were that cheap. I got quoted £100 just for a set of yokes. :face_screaming_in_fear:
            Rattle can to the rescue!!! :grinning_face_with_smiling_eyes:
            M 1 Reply Last reply
            • N NINJA
              M Offline
              M Offline
              mhbikesnbits
              @NINJA wow really what area are from , that’s expensive he does a top notch job too restores bikes himself so he knows the crack what’s good to paint and what’s not
              • M mhbikesnbits
                #107
                @mhbikesnbits Berkshire, sadly there's not too many coaters interested in 'small one off' type jobs in this neck of the woods. 🙁
                • O Offline
                  O Offline
                  It's difficult to find a coaters "sympathetic" to restoration as opposed to commercial work, you need an enthusiast. I rate my coater highly but even them I have returned the odd bit, but I am picky (why should I not be, I am paying). Maybe being a regular (ish) customer helps but the cost is reasonable to me, when I first went there made clear my expectations and they have accommodated my requirements. I am lucky there are several local to me but not all finishes available, need to find someone local who does anodising, would prefer that to painting my black bits.
                  • O Offline
                    O Offline
                    Can I ask where you found the 3et engine. Getting an itch I need to scratch! 3xp would be nice too
                    • O oldman
                      M Offline
                      M Offline
                      mhbikesnbits
                      @oldman I have a few anodisers around me I did think a couple of days ago actually,
                      maybe I should of, but it was just easier just send a load in one go for powder coat as the price is good for me and quality is amazing,
                      the 3et was listed on eBay for a while from a seller in Poland it had damage on the engine case as seen in a previous post that I have repaired which might have put people off but with much thought I decided to pull the trigger
                      • N NINJA
                        M Offline
                        M Offline
                        mhbikesnbits
                        @NINJA that’s a lil unlucky then no harm in using rattle paint tho instead I suppose, get more satisfaction doing the job yourself
                        • ChallengerC Offline
                          ChallengerC Offline
                          Challenger
                          Nice project! The crankcase damage in this engine occured because the owner didnt pay that much attention to the condition of the chain and sprockets, I recommend you changing the drivetrain from 428 to 520 for better strenght(just look for DT200R chain and sprockets, everything will fit bolt-on) and also use the chain lower guide(new avaible to buy cheap at yamaha dealer) in good condition, if you do that there will be no more problems with chain causing damage to the crankcases.
                          I raced the guy on that DT200R in 2016, it was only amateur cross-country type of championship but the WR200 turned out to be superior to DT :face_with_stuck-out_tongue: , 2 years later he sold me the bike.
                          Heres a pic of that DT, looked better than when i got her.
                          declanD M 2 Replies Last reply
                          4
                          • ChallengerC Challenger
                            @Challenger the dt is already having a lot of it’s power sapped a bigger chain is way overkill
                            ChallengerC M 2 Replies Last reply
                              ChallengerC Offline
                              ChallengerC Offline
                              Challenger
                              @declan Well you probably could fit a bicycle chain if youd try, but the 520 was standard in both two-hundreds, DT and WR. Im a bit of oem bikes and parts freak so thats the type Im using.
                                M Offline
                                M Offline
                                mhbikesnbits
                                @Challenger thanks for sharing buddy cracking picture, I would image yes maybe the case was damaged because of the chain and sprocket buyer didn’t specify why, could be a number of ways,
                                I’m unsure what chain size and sprocket size to use yet need to some research after I’ve rebuilt the engine and fitted it to the frame, Id prefer to get it to this stage before I start planning how to engineer the bike
                                  M Offline
                                  M Offline
                                  mhbikesnbits
                                  @declan positive and negatives in either way I suppose buddy
                                  • M Offline
                                    M Offline
                                    mhbikesnbits
                                    I’ve ordered and new workshop so planning that at the moment which is why there has not been much attention to the dt, also rebuilding my 1980 rm 80 engine, which I need to metal spray the crank as the bearing is to slack on one side of the crank wouldn’t want it spinning one bearing that’s for sure,
                                    Just for fun anyone want share a picture of there workshops/ garage ?
                                    • M Offline
                                      M Offline
                                      mhbikesnbits
                                      I also planning on doing restoration services for bikes, any model any part any type of restoration from nuts and bolts to full bike rebuilt anything you like what I’ve done on my build I can do, so if that’s somthing that Interests you guys let me know
                                      • M Offline
                                        M Offline
                                        mhbikesnbits
                                        #119
                                        engine back from the Powder coaters, happy with the results looking forward to rebuilding it up, just got to mill the writing on the custom ypvs cover as masking it wouldn’t look right
                                        I also need to spray the plastic covers because these can’t be powder coated
                                          Wow, that really looks pucker.
                                          I was always too scared to get my engines powdercoated.
                                          The results look grand though.
