  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 130.1k Views 3 Watching
  • O oldman
    It's difficult to find a coaters "sympathetic" to restoration as opposed to commercial work, you need an enthusiast. I rate my coater highly but even them I have returned the odd bit, but I am picky (why should I not be, I am paying). Maybe being a regular (ish) customer helps but the cost is reasonable to me, when I first went there made clear my expectations and they have accommodated my requirements. I am lucky there are several local to me but not all finishes available, need to find someone local who does anodising, would prefer that to painting my black bits.
    M
    M
    mhbikesnbits
    @oldman I have a few anodisers around me I did think a couple of days ago actually,
    maybe I should of, but it was just easier just send a load in one go for powder coat as the price is good for me and quality is amazing,
    the 3et was listed on eBay for a while from a seller in Poland it had damage on the engine case as seen in a previous post that I have repaired which might have put people off but with much thought I decided to pull the trigger
      @mhbikesnbits Berkshire, sadly there's not too many coaters interested in 'small one off' type jobs in this neck of the woods. 🙁
      M
      M
      mhbikesnbits
      @NINJA that’s a lil unlucky then no harm in using rattle paint tho instead I suppose, get more satisfaction doing the job yourself
      • ChallengerC
        ChallengerC
        Challenger
        Nice project! The crankcase damage in this engine occured because the owner didnt pay that much attention to the condition of the chain and sprockets, I recommend you changing the drivetrain from 428 to 520 for better strenght(just look for DT200R chain and sprockets, everything will fit bolt-on) and also use the chain lower guide(new avaible to buy cheap at yamaha dealer) in good condition, if you do that there will be no more problems with chain causing damage to the crankcases.
        I raced the guy on that DT200R in 2016, it was only amateur cross-country type of championship but the WR200 turned out to be superior to DT :face_with_stuck-out_tongue: , 2 years later he sold me the bike.
        Heres a pic of that DT, looked better than when i got her.
        declanD M 2 Replies Last reply
        4
        • ChallengerC Challenger
          @Challenger the dt is already having a lot of it’s power sapped a bigger chain is way overkill
          ChallengerC M 2 Replies Last reply
            ChallengerC
            ChallengerC
            Challenger
            @declan Well you probably could fit a bicycle chain if youd try, but the 520 was standard in both two-hundreds, DT and WR. Im a bit of oem bikes and parts freak so thats the type Im using.
              M
              M
              mhbikesnbits
              @Challenger thanks for sharing buddy cracking picture, I would image yes maybe the case was damaged because of the chain and sprocket buyer didn’t specify why, could be a number of ways,
              I’m unsure what chain size and sprocket size to use yet need to some research after I’ve rebuilt the engine and fitted it to the frame, Id prefer to get it to this stage before I start planning how to engineer the bike
                M
                M
                mhbikesnbits
                @declan positive and negatives in either way I suppose buddy
                • M
                  M
                  mhbikesnbits
                  I’ve ordered and new workshop so planning that at the moment which is why there has not been much attention to the dt, also rebuilding my 1980 rm 80 engine, which I need to metal spray the crank as the bearing is to slack on one side of the crank wouldn’t want it spinning one bearing that’s for sure,
                  Just for fun anyone want share a picture of there workshops/ garage ?
                  • M
                    M
                    mhbikesnbits
                    I also planning on doing restoration services for bikes, any model any part any type of restoration from nuts and bolts to full bike rebuilt anything you like what I’ve done on my build I can do, so if that’s somthing that Interests you guys let me know
                    • M
                      M
                      mhbikesnbits
                      #119
                      engine back from the Powder coaters, happy with the results looking forward to rebuilding it up, just got to mill the writing on the custom ypvs cover as masking it wouldn’t look right
                      I also need to spray the plastic covers because these can’t be powder coated
                        Wow, that really looks pucker.
                        I was always too scared to get my engines powdercoated.
                        The results look grand though.
                        M 1 Reply Last reply
                          M
                          M
                          mhbikesnbits
                          @Calum cheers it’s a first time for me to be honest, I’m quite impressed with the results just see how it holds up to the road once the bike complete I guess
                          • Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            I cant belive how fantastic all this is looking i really hope mine looks as good at this once its done.
                              M
                              M
                              mhbikesnbits
                              @Walney-Reptiles thanks for your kind words quite abit to do yet till it’s done, but I really like your project too think your doing a amazing job
                              • M mhbikesnbits
                                Walney-ReptilesW
                                Walney-ReptilesW
                                Walney-Reptiles
                                @mhbikesnbits Your welcome mate, and thanks very much 😄 what time next year do you think you will have finished, i reckon by april next year mine should be completed
                                • M
                                  M
                                  mhbikesnbits
                                  Happy new everyone and all the best to all!
                                  not had chance do any work on my dt recently unfortunately but hopefully this is the year to get things done on a plus just found this what I think would look ace on the project
                                  • M
                                    M
                                    mhbikesnbits
                                    Well been a while since I’ve posted on this article, i just want to say the project is alive and well I’m making some progression finally. I blame a pregnancy and a pandemic for the delay 😂
                                    Forget how I post picture on here will update some soon
                                    S CalumC 2 Replies Last reply
                                    • M mhbikesnbits
                                      @mhbikesnbits
                                      Sweet, I’ve not seen your project before. Some really nice attention to details 👍
                                      Please, keep on keeping on 🐾 ...
                                      • M mhbikesnbits
                                        @mhbikesnbits Yes wow blast from the past. Hard to think your last post was pre-pandemic. It's hard to even remember what life was like back then 😞
                                          @mhbikesnbits
                                          M
                                          M
                                          mhbikesnbits
                                          @SpookDog tar buddy Hopefully a lot more of it come
