  4. Dangerous running both high and lowbeam?
9 Posts 5 Posters 1.4k Views
  • Irongamer727I Offline
    wrote on last edited by Irongamer727
    My issue is that I want both the low and highbeam lit at the same time. Now when I put on my highbeam the lowbeam goes out. Do I risk burning the reflector running with them both?
    Note: Its not a DT125
      Anyone? Expertise needed
        I mean, no expertise, but I'm sure it'll have an impact. The lighting system is the most expensive system on the vehicle. So it will have an impact. Not sure what though.
        • Irongamer727I Irongamer727
          @Irongamer727 can I ask why?
            @declan light is much stronger when I use both
              @Irongamer727 what bulb you running
                @declan osram night breaker lazer. The most expensive I could find.
                • O Offline
                  O Offline
                  You run the chance of overloading the loom and components running both simultaneously, would not do personally
                  • D Offline
                    dan28
                    how do you use both you push the switch for main beam
                    i would put a multimeter on the wires sounds like its not getting enough power if its dull
