  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 20.1k Views 1 Watching
  • J jonne123
    Do you recommend carbon fiber reeds?
    Walney-ReptilesW
    Walney-ReptilesW
    Walney-Reptiles
    wrote on last edited by Walney-Reptiles
    #61
    @jonne123 there,s a few topics on this site already buddy try reading through them, this is for posting about my progress on my project
    https://dt125r.co.uk/topic/790/recommended-reeds
    • T
      T
      theportingmaster
      Hi @Walney-Reptiles used a K135 main jet with a K38 slow jet fitted to a standard airbox. Bike had a Gianelli full system on it.
      Walney-ReptilesW 1 Reply Last reply
      • T
        T
        theportingmaster
        Hi @jonne123 carbon reeds only make a difference really to fully modified engines when all other mods are done as it is a
        combination of all tuning mods matched that makes a difference and carbon reeds do nothing for a standard engine.
        I fit them to most engines I build as make them myself as easy to make them and cost around £1 a set to make.
        • T theportingmaster
          Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          @theportingmaster said in 2003 Yamaha Dt125R Project:
          K38 slow jet
          cheers buddy, il be getting a limited edition stainless steel and silencer exhaust from portugal in the next few months, will upload photos when its arrived!
          • Walney-ReptilesW
            Walney-ReptilesW
            Walney-Reptiles
            #65
            Soo i have come to a very hard decision and have somthink i need to say and i would like everyone that see's this to have a read
            All of the above parts (forks, engine, carb, frame, wiring loom + other bits that are not on here,are going up for sale) any questions please ask
            all stuff for sale (Buyer sorts courier or Collection)
            Engine + Carb + Wiring loom Will be soild as one unit Open to Decent offers around £650
            Engine (Fully rebuilt check the above posts out)
            Carb PWK32 Keihin (Brand new never used)
            Wiring loom + 3RM-20 CDI + PV servo (Wiring loom Needs a little work, no ignition switch, no indicator wiring as the loom was made bare for green laning less stuff togo wrong when out and off roading)
            WR426F + aliminium adapter + New head set bearings dust sheilds and shims (No wheel or caliper or Disc) (also see posts above) (£160 OVNO)
            WR 200 Swingarm + Caliper and Carrier £115 OVNO (Can get photos by Request) Open to offers
            Frame + tank + Rad as it is Needs sand blasting and powder coating in buyers color choice, the frame has had nuts welded onto the original nuts where the original ones stripped out and has had the rear brake master cylinder mount reinforced with 4mm steel welded on Comes with V5 also has a WR125 Rad with rubber vibration mounts fitted and Red fan will need wiring up to the bike fitted to the standard rad mount tank still fits on with the plastics extra pipe fittings on the rad may need blanking off (Price will be how ever much the powder coating costs + £200) can get photos by request
            Other bits i have are two rims front and rear they need blasting and powder coating no hubs no spokes i have New bearings for the DTR hubs can get photos by request... Open to offers
            cant name all the parts i have off hand but if you want to know if i have a part ask and i will see if i have the parts
            • Walney-ReptilesW Walney-Reptiles
              @Walney-Reptiles Ah sorry to hear this bud.
              Can you not post in the for sale section?
                Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                @Calum Il copy and paste it into the forsale section but id like to leave it in here too as all the pics etc... are in here
                • L
                  L
                  Lukas
                  i know that this is quite a old conversation but if you still have the dt125 and you want more power, a yz125 1989-1993 engine atleast fits perfectly with the swingarm and you just have to make like 2 head mounts from sheet steel, i did that to mine cause well the cylinder fucked up and i had a yz laying around because i was doing a dyz project anyway, so i sold my other damaged dt125 frame and just built it in my main bike where i kept the dt frame for plates and the frame number and everything else on it is from a yz
