  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.1k Views 1 Watching
  • T
    T
    theportingmaster
    Previously fitted a PWK 32 carb to a 2003 dt and the carb is quite small pictured next to a Mikuni TM 30. Fitted it to a modified 2003 dt inlet manifold, throttle cable outer needs shortening by 30mm carb end and with a warm air filter rubber fits over.
    • T theportingmaster
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @theportingmaster cheersa for your post mate ill have to stick with the PWK32 or now as it was a crimbo prezzie, what jet size did you use on the pwk on the 2003 dt? would be good to know. cheers buddy!
        jonne123
        Do you recommend carbon fiber reeds?
        • J jonne123
          Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          wrote on last edited by Walney-Reptiles
          #61
          @jonne123 there,s a few topics on this site already buddy try reading through them, this is for posting about my progress on my project
          https://dt125r.co.uk/topic/790/recommended-reeds
          • T
            T
            theportingmaster
            Hi @Walney-Reptiles used a K135 main jet with a K38 slow jet fitted to a standard airbox. Bike had a Gianelli full system on it.
            • T
              T
              theportingmaster
              Hi @jonne123 carbon reeds only make a difference really to fully modified engines when all other mods are done as it is a
              combination of all tuning mods matched that makes a difference and carbon reeds do nothing for a standard engine.
              I fit them to most engines I build as make them myself as easy to make them and cost around £1 a set to make.
                Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                @theportingmaster said in 2003 Yamaha Dt125R Project:
                K38 slow jet
                cheers buddy, il be getting a limited edition stainless steel and silencer exhaust from portugal in the next few months, will upload photos when its arrived!
                • Walney-ReptilesW
                  Walney-ReptilesW
                  Walney-Reptiles
                  #65
                  Soo i have come to a very hard decision and have somthink i need to say and i would like everyone that see's this to have a read
                  All of the above parts (forks, engine, carb, frame, wiring loom + other bits that are not on here,are going up for sale) any questions please ask
                  all stuff for sale (Buyer sorts courier or Collection)
                  Engine + Carb + Wiring loom Will be soild as one unit Open to Decent offers around £650
                  Engine (Fully rebuilt check the above posts out)
                  Carb PWK32 Keihin (Brand new never used)
                  Wiring loom + 3RM-20 CDI + PV servo (Wiring loom Needs a little work, no ignition switch, no indicator wiring as the loom was made bare for green laning less stuff togo wrong when out and off roading)
                  WR426F + aliminium adapter + New head set bearings dust sheilds and shims (No wheel or caliper or Disc) (also see posts above) (£160 OVNO)
                  WR 200 Swingarm + Caliper and Carrier £115 OVNO (Can get photos by Request) Open to offers
                  Frame + tank + Rad as it is Needs sand blasting and powder coating in buyers color choice, the frame has had nuts welded onto the original nuts where the original ones stripped out and has had the rear brake master cylinder mount reinforced with 4mm steel welded on Comes with V5 also has a WR125 Rad with rubber vibration mounts fitted and Red fan will need wiring up to the bike fitted to the standard rad mount tank still fits on with the plastics extra pipe fittings on the rad may need blanking off (Price will be how ever much the powder coating costs + £200) can get photos by request
                  Other bits i have are two rims front and rear they need blasting and powder coating no hubs no spokes i have New bearings for the DTR hubs can get photos by request... Open to offers
                  cant name all the parts i have off hand but if you want to know if i have a part ask and i will see if i have the parts
                    @Walney-Reptiles Ah sorry to hear this bud.
                    Can you not post in the for sale section?
                      Walney-ReptilesW
                      Walney-ReptilesW
                      Walney-Reptiles
                      @Calum Il copy and paste it into the forsale section but id like to leave it in here too as all the pics etc... are in here
                      • L
                        L
                        Lukas
                        i know that this is quite a old conversation but if you still have the dt125 and you want more power, a yz125 1989-1993 engine atleast fits perfectly with the swingarm and you just have to make like 2 head mounts from sheet steel, i did that to mine cause well the cylinder fucked up and i had a yz laying around because i was doing a dyz project anyway, so i sold my other damaged dt125 frame and just built it in my main bike where i kept the dt frame for plates and the frame number and everything else on it is from a yz
