  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.1k Views 1 Watching
    Project Update
    My forks arrived today
    Please welcome my WR426F forks 😉
    They are in decent nick for £150 they have Adjustable Compression Hardness on the bottom and Adjustable Dampening on the top, Bearings seam to be a perfect fit all i got todo is but a spacer under the bottom of the bottom taper bearing 😉
    Sorry for bad photos
    @Walney-Reptiles Those forks look damn good dude. 👍
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @NINJA cheers mate 😄
      • Walney-ReptilesW
        Walney-ReptilesW
        Walney-Reptiles
        A Big Thanks to @Challenger For Selling me the WR200 Swing arm, Caliper Carrier And Caliper 😄
        (This Bike Gunna Be A Beast!!!)
        • Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          wrote on last edited by Walney-Reptiles
          #52
          Project Update!!
          Soo i have had to Design a HeadSet Spacer for my new forks to fit, as the new taper bearing for the old forks dosnt fit the steering shaft on my new forks so i have designed this using Onshape, I have Ordered some Alliminium Tube which is 56mmOD 32mmID 12mmWall 200mm in lenth for £15 next thing todo is 3Dprint a Prototype then test fit then get my freind's Lathe going and make one out of the Alliminium 😄
          • Walney-ReptilesW
            Walney-ReptilesW
            Walney-Reptiles
            well guys for chrismas i got a PKW 32 keihin carb off my old man Looks mint he said its good for a 125cc upto a tuned 200cc 😄 will upload photos later on.
            O 1 Reply Last reply
              @Walney-Reptiles your dad is a good man!
              • Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                heres some photos all shiney and new 😄
                • ChallengerC
                  ChallengerC
                  Challenger
                  The carb looks tall for a DT, did you try fitting it already? Maybe only the gas linkage mount will need changing.
                    Should be okay, I don't recall there being height clearance issues when fitting the VHSA. Be good to see how this fairs up.
                    • T
                      T
                      theportingmaster
                      Previously fitted a PWK 32 carb to a 2003 dt and the carb is quite small pictured next to a Mikuni TM 30. Fitted it to a modified 2003 dt inlet manifold, throttle cable outer needs shortening by 30mm carb end and with a warm air filter rubber fits over.
                      • T theportingmaster
                        Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        @theportingmaster cheersa for your post mate ill have to stick with the PWK32 or now as it was a crimbo prezzie, what jet size did you use on the pwk on the 2003 dt? would be good to know. cheers buddy!
                          jonne123
                          Do you recommend carbon fiber reeds?
                          • J jonne123
                            Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            #61
                            @jonne123 there,s a few topics on this site already buddy try reading through them, this is for posting about my progress on my project
                            https://dt125r.co.uk/topic/790/recommended-reeds
                            • T
                              T
                              theportingmaster
                              Hi @Walney-Reptiles used a K135 main jet with a K38 slow jet fitted to a standard airbox. Bike had a Gianelli full system on it.
                              • T
                                T
                                theportingmaster
                                Hi @jonne123 carbon reeds only make a difference really to fully modified engines when all other mods are done as it is a
                                combination of all tuning mods matched that makes a difference and carbon reeds do nothing for a standard engine.
                                I fit them to most engines I build as make them myself as easy to make them and cost around £1 a set to make.
                                  Walney-ReptilesW
                                  Walney-ReptilesW
                                  Walney-Reptiles
                                  @theportingmaster said in 2003 Yamaha Dt125R Project:
                                  K38 slow jet
                                  cheers buddy, il be getting a limited edition stainless steel and silencer exhaust from portugal in the next few months, will upload photos when its arrived!
                                  • Walney-ReptilesW
                                    Walney-ReptilesW
                                    Walney-Reptiles
                                    #65
                                    Soo i have come to a very hard decision and have somthink i need to say and i would like everyone that see's this to have a read
                                    All of the above parts (forks, engine, carb, frame, wiring loom + other bits that are not on here,are going up for sale) any questions please ask
                                    all stuff for sale (Buyer sorts courier or Collection)
                                    Engine + Carb + Wiring loom Will be soild as one unit Open to Decent offers around £650
                                    Engine (Fully rebuilt check the above posts out)
                                    Carb PWK32 Keihin (Brand new never used)
                                    Wiring loom + 3RM-20 CDI + PV servo (Wiring loom Needs a little work, no ignition switch, no indicator wiring as the loom was made bare for green laning less stuff togo wrong when out and off roading)
                                    WR426F + aliminium adapter + New head set bearings dust sheilds and shims (No wheel or caliper or Disc) (also see posts above) (£160 OVNO)
                                    WR 200 Swingarm + Caliper and Carrier £115 OVNO (Can get photos by Request) Open to offers
                                    Frame + tank + Rad as it is Needs sand blasting and powder coating in buyers color choice, the frame has had nuts welded onto the original nuts where the original ones stripped out and has had the rear brake master cylinder mount reinforced with 4mm steel welded on Comes with V5 also has a WR125 Rad with rubber vibration mounts fitted and Red fan will need wiring up to the bike fitted to the standard rad mount tank still fits on with the plastics extra pipe fittings on the rad may need blanking off (Price will be how ever much the powder coating costs + £200) can get photos by request
                                    Other bits i have are two rims front and rear they need blasting and powder coating no hubs no spokes i have New bearings for the DTR hubs can get photos by request... Open to offers
                                    cant name all the parts i have off hand but if you want to know if i have a part ask and i will see if i have the parts
                                      @Walney-Reptiles Ah sorry to hear this bud.
                                      Can you not post in the for sale section?
                                        Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        @Calum Il copy and paste it into the forsale section but id like to leave it in here too as all the pics etc... are in here
                                        • L
                                          L
                                          Lukas
                                          i know that this is quite a old conversation but if you still have the dt125 and you want more power, a yz125 1989-1993 engine atleast fits perfectly with the swingarm and you just have to make like 2 head mounts from sheet steel, i did that to mine cause well the cylinder fucked up and i had a yz laying around because i was doing a dyz project anyway, so i sold my other damaged dt125 frame and just built it in my main bike where i kept the dt frame for plates and the frame number and everything else on it is from a yz
