  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 20.1k Views 1 Watching
  • Walney-ReptilesW Walney-Reptiles
    ebay mate heres the link if its allowed it cost £110 but it beats paying £355 from MSP
    https://www.ebay.co.uk/itm/Yamaha-DT-125-R-RE-X-SM-1988-2010-Rear-Suspension-Linkage-Bearing-Service-Kit/273964244490?hash=item3fc98a9e0a:g:Wd4AAOSwJppdUVu3
    @Walney-Reptiles don’t suppose you could measure those linkage seals for me bud?
    Walney-ReptilesW 1 Reply Last reply
      @Calum I agree there mate, I will be getting a new carb ANY advice on carbs? im not after the cheapest one or the most expensive one also i will be getting one of them zeeltronic CDI's for my bike but id like to know if anyone on here has set one up? currently i have the 3RM-20 cdi units would the zeeltronic CDI replace that? i also use the PV System.
      clawsC
      clawsC
      claws
      @Walney-Reptiles well with your setup i would recommend some 28mm - 32mm carb. for example a mikuni tm28 or a keihin pwk 28. im running a keihin pwk 36 on my dt but i have a 170cc kit on it. its still too big for the bike
        Walney-ReptilesW
        Walney-ReptilesW
        Walney-Reptiles
        @declan said in 2003 Yamaha Dt125R Project:
        I wont be able to get you the sizes until i go back to work on Monday as i keep everythink there as it where im going tobe rebuilding my bike
        @claws said in 2003 Yamaha Dt125R Project:
        cheers buddy, il keep this in-mind
        • Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          Project update !!!
          I have just ordered WR426F front forks to fit on my DTR 😄
            @Walney-Reptiles I’d appreciate it if you don’t mind
              Well i have made some more orders list below
              Head race bearings
              Linkage bearings and bushes
              Rear swing arm bearings
              Frunt wheel and Rear wheel bearings
              in total £186.59
              Heres a list with everythink i have bought since i started the project back in july including the above..
              Athena 125cc cylinderhead kit £429.95
              All bearings in engine (SimplyBearings.co.uk) one from pjme £128.09
              All bearings on frame and wheels (coming from ebay.co.uk) £186.59
              Athena full oilseals (from ebay.co.uk) £33.95
              Athena Full gasket set (from ebay.co.uk) £29.99
              MSP (replacment bits for inside engine that i lost) £45.48
              Sub Total £854.05 SO FAR
              I estimate there will be atleast £600-£700 more ontop left to be spent before it is complete
              M
              M
              mhbikesnbits
              @Walney-Reptiles ouch expensive for the bearings if you ever need bearings feel free tobgive me shout they shouldn’t be that much even for top line bearings
              • M mhbikesnbits
                Walney-ReptilesW
                Walney-ReptilesW
                Walney-Reptiles
                @mhbikesnbits Cheers buddy do you sell things on ebay or do you own a shop?
                • Walney-ReptilesW
                  Walney-ReptilesW
                  Walney-Reptiles
                  Project Update
                  My forks arrived today
                  Please welcome my WR426F forks 😉
                  They are in decent nick for £150 they have Adjustable Compression Hardness on the bottom and Adjustable Dampening on the top, Bearings seam to be a perfect fit all i got todo is but a spacer under the bottom of the bottom taper bearing 😉
                  Sorry for bad photos
                    Project Update
                    @Walney-Reptiles Those forks look damn good dude. 👍
                      Walney-ReptilesW
                      Walney-ReptilesW
                      Walney-Reptiles
                      @NINJA cheers mate 😄
                      • Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        A Big Thanks to @Challenger For Selling me the WR200 Swing arm, Caliper Carrier And Caliper 😄
                        (This Bike Gunna Be A Beast!!!)
                        • Walney-ReptilesW
                          Walney-ReptilesW
                          Walney-Reptiles
                          wrote on last edited by Walney-Reptiles
                          #52
                          Project Update!!
                          Soo i have had to Design a HeadSet Spacer for my new forks to fit, as the new taper bearing for the old forks dosnt fit the steering shaft on my new forks so i have designed this using Onshape, I have Ordered some Alliminium Tube which is 56mmOD 32mmID 12mmWall 200mm in lenth for £15 next thing todo is 3Dprint a Prototype then test fit then get my freind's Lathe going and make one out of the Alliminium 😄
                          • Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            well guys for chrismas i got a PKW 32 keihin carb off my old man Looks mint he said its good for a 125cc upto a tuned 200cc 😄 will upload photos later on.
                            O 1 Reply Last reply
                              O
                              O
                              @Walney-Reptiles your dad is a good man!
                              • Walney-ReptilesW
                                Walney-ReptilesW
                                Walney-Reptiles
                                heres some photos all shiney and new 😄
                                • ChallengerC
                                  ChallengerC
                                  Challenger
                                  The carb looks tall for a DT, did you try fitting it already? Maybe only the gas linkage mount will need changing.
                                    Should be okay, I don't recall there being height clearance issues when fitting the VHSA. Be good to see how this fairs up.
                                    • T
                                      T
                                      theportingmaster
                                      Previously fitted a PWK 32 carb to a 2003 dt and the carb is quite small pictured next to a Mikuni TM 30. Fitted it to a modified 2003 dt inlet manifold, throttle cable outer needs shortening by 30mm carb end and with a warm air filter rubber fits over.
                                      • T theportingmaster
                                        Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        @theportingmaster cheersa for your post mate ill have to stick with the PWK32 or now as it was a crimbo prezzie, what jet size did you use on the pwk on the 2003 dt? would be good to know. cheers buddy!
                                          jonne123
                                          Do you recommend carbon fiber reeds?
