  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.9k Views 1 Watching
    Oh sweet bud. Sounds very expensive, but if its a job worth doing it's worth doing right.
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @Calum I agree there mate, I will be getting a new carb ANY advice on carbs? im not after the cheapest one or the most expensive one also i will be getting one of them zeeltronic CDI's for my bike but id like to know if anyone on here has set one up? currently i have the 3RM-20 cdi units would the zeeltronic CDI replace that? i also use the PV System.
      clawsC 1 Reply Last reply
      • Walney-ReptilesW
        Walney-ReptilesW
        Walney-Reptiles
        So i have Just ordered some more bits...
        Yamaha WR125X Radiator With 12v fan (Im going to fabricate my own mounts for this so dont worry if you think it wont fit ordered this because my DTR one is Crap and the wr one was only £32 with free postage)
        Also ordered
        a second Rad fan witch was £18
        DT125R Stainless Engine mounting allen bolts
        Just an extra note im going to cut the elbow off the bottom of the radiator and spin it to point the correct way 🙂
        • Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          Well i have had some Post Today 🙂
          Swingarm bearings and bushes and seals aka service kit
          Linkage bearings and bushes and seals aka service kit
          Head race Taper bearings top and bottom
          M 1 Reply Last reply
            M
            M
            morty
            @Walney-Reptiles where’d you get the linkage kit from pal?
            • Walney-ReptilesW
              Walney-ReptilesW
              Walney-Reptiles
              ebay mate heres the link if its allowed it cost £110 but it beats paying £355 from MSP
              https://www.ebay.co.uk/itm/Yamaha-DT-125-R-RE-X-SM-1988-2010-Rear-Suspension-Linkage-Bearing-Service-Kit/273964244490?hash=item3fc98a9e0a:g:Wd4AAOSwJppdUVu3
                @Walney-Reptiles don’t suppose you could measure those linkage seals for me bud?
                  clawsC
                  clawsC
                  claws
                  @Walney-Reptiles well with your setup i would recommend some 28mm - 32mm carb. for example a mikuni tm28 or a keihin pwk 28. im running a keihin pwk 36 on my dt but i have a 170cc kit on it. its still too big for the bike
                    Walney-ReptilesW
                    Walney-ReptilesW
                    Walney-Reptiles
                    @declan said in 2003 Yamaha Dt125R Project:
                    I wont be able to get you the sizes until i go back to work on Monday as i keep everythink there as it where im going tobe rebuilding my bike
                    @claws said in 2003 Yamaha Dt125R Project:
                    cheers buddy, il keep this in-mind
                    • Walney-ReptilesW
                      Walney-ReptilesW
                      Walney-Reptiles
                      Project update !!!
                      I have just ordered WR426F front forks to fit on my DTR 😄
                        @Walney-Reptiles I’d appreciate it if you don’t mind
                          Well i have made some more orders list below
                          Head race bearings
                          Rear swing arm bearings
                          Frunt wheel and Rear wheel bearings
                          in total £186.59
                          Heres a list with everythink i have bought since i started the project back in july including the above..
                          Athena 125cc cylinderhead kit £429.95
                          All bearings in engine (SimplyBearings.co.uk) one from pjme £128.09
                          All bearings on frame and wheels (coming from ebay.co.uk) £186.59
                          Athena full oilseals (from ebay.co.uk) £33.95
                          Athena Full gasket set (from ebay.co.uk) £29.99
                          MSP (replacment bits for inside engine that i lost) £45.48
                          Sub Total £854.05 SO FAR
                          I estimate there will be atleast £600-£700 more ontop left to be spent before it is complete
                          M
                          M
                          mhbikesnbits
                          @Walney-Reptiles ouch expensive for the bearings if you ever need bearings feel free tobgive me shout they shouldn’t be that much even for top line bearings
                          • M mhbikesnbits
                            Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            @mhbikesnbits Cheers buddy do you sell things on ebay or do you own a shop?
                            • Walney-ReptilesW
                              Walney-ReptilesW
                              Walney-Reptiles
                              Project Update
                              My forks arrived today
                              Please welcome my WR426F forks 😉
                              They are in decent nick for £150 they have Adjustable Compression Hardness on the bottom and Adjustable Dampening on the top, Bearings seam to be a perfect fit all i got todo is but a spacer under the bottom of the bottom taper bearing 😉
                              Sorry for bad photos
                                Project Update
                                @Walney-Reptiles Those forks look damn good dude. 👍
                                  Walney-ReptilesW
                                  Walney-ReptilesW
                                  Walney-Reptiles
                                  @NINJA cheers mate 😄
                                  • Walney-ReptilesW
                                    Walney-ReptilesW
                                    Walney-Reptiles
                                    A Big Thanks to @Challenger For Selling me the WR200 Swing arm, Caliper Carrier And Caliper 😄
                                    (This Bike Gunna Be A Beast!!!)
                                    • Walney-ReptilesW
                                      Walney-ReptilesW
                                      Walney-Reptiles
                                      wrote on last edited by Walney-Reptiles
                                      #52
                                      Project Update!!
                                      Soo i have had to Design a HeadSet Spacer for my new forks to fit, as the new taper bearing for the old forks dosnt fit the steering shaft on my new forks so i have designed this using Onshape, I have Ordered some Alliminium Tube which is 56mmOD 32mmID 12mmWall 200mm in lenth for £15 next thing todo is 3Dprint a Prototype then test fit then get my freind's Lathe going and make one out of the Alliminium 😄
                                      • Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        well guys for chrismas i got a PKW 32 keihin carb off my old man Looks mint he said its good for a 125cc upto a tuned 200cc 😄 will upload photos later on.
                                        O 1 Reply Last reply
                                          @Walney-Reptiles your dad is a good man!
