  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.1k Views 1 Watching
    @DTR-NSR i dont have them no more there was nawt left of them anychance you may have old ones laying around to get numbers off?
    @Walney-Reptiles you need linkage stuff or swing arm stuff?
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @declan I need the linkage stuff
      • Walney-ReptilesW
        Walney-ReptilesW
        Walney-Reptiles
        Also can someone link me to the upgrade bearings for the headset on the 2002 yamaha dtr?
          @Walney-Reptiles There are upgradable bearings?
            Walney-ReptilesW
            Walney-ReptilesW
            Walney-Reptiles
            @Calum well i say that what i mean is you can change the top bearing to taper bearings instead of the standard ring bearing
              @Walney-Reptiles Not without changing the the yokes/bearing cup.
              I done it cause I fitted USDs. But otherwise, no. Or I'm sure it could be done, but what would be the point?
                @Calum my dt is fitted with tapper bearings top and bottom with out modifications, tapper bearings are able to cope with greater loads so generally last longer.
                • D DTR+NSR
                  @DTR-NSR Cool, hit the geezer up! I didn't know it was a thing.
                  My DT was stolen and ramped. Forks bent, wheels bent, bearings in the head tube was fine. They are robust enough. Obviously Taper has its advantages.
                  • Walney-ReptilesW
                    Walney-ReptilesW
                    Walney-Reptiles
                    wrote on last edited by Walney-Reptiles
                    #34
                    Well i have made some more orders list below
                    Head race bearings
                    Linkage bearings and bushes
                    Rear swing arm bearings
                    Frunt wheel and Rear wheel bearings
                    in total £186.59
                    Heres a list with everythink i have bought since i started the project back in july including the above..
                    Athena 125cc cylinderhead kit £429.95
                    All bearings in engine (SimplyBearings.co.uk) one from pjme £128.09
                    All bearings on frame and wheels (coming from ebay.co.uk) £186.59
                    Athena full oilseals (from ebay.co.uk) £33.95
                    Athena Full gasket set (from ebay.co.uk) £29.99
                    MSP (replacment bits for inside engine that i lost) £45.48
                    Sub Total £854.05 SO FAR
                    I estimate there will be atleast £600-£700 more ontop left to be spent before it is complete
                    M 1 Reply Last reply
                      Oh sweet bud. Sounds very expensive, but if its a job worth doing it's worth doing right.
                        Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        @Calum I agree there mate, I will be getting a new carb ANY advice on carbs? im not after the cheapest one or the most expensive one also i will be getting one of them zeeltronic CDI's for my bike but id like to know if anyone on here has set one up? currently i have the 3RM-20 cdi units would the zeeltronic CDI replace that? i also use the PV System.
                        clawsC 1 Reply Last reply
                        • Walney-ReptilesW
                          Walney-ReptilesW
                          Walney-Reptiles
                          So i have Just ordered some more bits...
                          Yamaha WR125X Radiator With 12v fan (Im going to fabricate my own mounts for this so dont worry if you think it wont fit ordered this because my DTR one is Crap and the wr one was only £32 with free postage)
                          Also ordered
                          a second Rad fan witch was £18
                          DT125R Stainless Engine mounting allen bolts
                          Just an extra note im going to cut the elbow off the bottom of the radiator and spin it to point the correct way 🙂
                          • Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            Well i have had some Post Today 🙂
                            Swingarm bearings and bushes and seals aka service kit
                            Linkage bearings and bushes and seals aka service kit
                            Head race Taper bearings top and bottom
                              M
                              M
                              morty
                              @Walney-Reptiles where’d you get the linkage kit from pal?
                              • Walney-ReptilesW
                                Walney-ReptilesW
                                Walney-Reptiles
                                ebay mate heres the link if its allowed it cost £110 but it beats paying £355 from MSP
                                https://www.ebay.co.uk/itm/Yamaha-DT-125-R-RE-X-SM-1988-2010-Rear-Suspension-Linkage-Bearing-Service-Kit/273964244490?hash=item3fc98a9e0a:g:Wd4AAOSwJppdUVu3
                                  @Walney-Reptiles don’t suppose you could measure those linkage seals for me bud?
                                    clawsC
                                    clawsC
                                    claws
                                    @Walney-Reptiles well with your setup i would recommend some 28mm - 32mm carb. for example a mikuni tm28 or a keihin pwk 28. im running a keihin pwk 36 on my dt but i have a 170cc kit on it. its still too big for the bike
                                      Walney-ReptilesW
                                      Walney-ReptilesW
                                      Walney-Reptiles
                                      @declan said in 2003 Yamaha Dt125R Project:
                                      I wont be able to get you the sizes until i go back to work on Monday as i keep everythink there as it where im going tobe rebuilding my bike
                                      @claws said in 2003 Yamaha Dt125R Project:
                                      cheers buddy, il keep this in-mind
                                      • Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        Project update !!!
                                        I have just ordered WR426F front forks to fit on my DTR 😄
                                          @Walney-Reptiles I’d appreciate it if you don’t mind
