  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.9k Views 1 Watching
    Update So i have started to rebuild my Yamaha DTR 125 Engine today
    New Bearings Fitted Replaced all of them!
    New Athena Oil Seals Fitted!
    New Stainless steel allan bolts!
    Gear Box Back in one piece πŸ˜„
    Tomorrow i will be doing the Clutch and Balance shaft and all the gears that connect the Balance shaft and crank shaft together. i will also be putting my new athena barrel on then when the missing spacer washers arrive il put the head on.
    Heres some photos of todays progress in order
    Didnt need the manual much as this will be the 10th time of rebuilding these engines πŸ˜› Super happy that im getting closer to my DTR Dream!!
    @Walney-Reptiles Shiny!!! :thumbs_up_medium-light_skin_tone: :oncoming_fist_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
    • Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      well im very happy to say that i have now finished putting my engine back togeather im just wating on a few bits from ethena to finish puting my cylinder head on but the rest is done πŸ˜„ Heres some photos
      So upto now i have replaced with new
      Stainless bolts
      All Koyo bearings
      all Athena Oil seals
      All Athena Gaskets
      New Athena topend
      now i have all the rest of the bike to sort out,let me know what you guys think
        Stainless bolts
        All Koyo bearings
        All Athena Gaskets
        New Athena topend
        @Walney-Reptiles it’s so nice!
          Stainless bolts
          All Koyo bearings
          All Athena Gaskets
          New Athena topend
          • M
            M
            mhbikesnbits
            Looks very well I like it
              Walney-ReptilesW
              Walney-ReptilesW
              Walney-Reptiles
              @declan @NINJA @mhbikesnbits
              Cheers guys! Its been a long time coming, most of the time it took me to rebuild it was waiting for parts from MSP but least i know the engine is 100% good to go, just need to get the rest of the bike going now.
                Very smart πŸ˜ƒ
                • Walney-ReptilesW
                  Walney-ReptilesW
                  Walney-Reptiles
                  Hiya again folks
                  So i have some good news i have started at a garage as a welder / fabricator repairing rotten sills on vans, cars, buses etc....
                  My boss is kind enough to let me redo and weld new nuts and other work to all my parts before he sends it all off for powder coating, i have one question regarding the suspention linkage and bushes etc... I dont want to pay Β£355 for genuine yamah bearings and oil seals etc... so i want to know what size bearings i can get as a replacment instead of the standard roller bearings i wanna use ball bearings instead anyone know what size bearings i will need?
                    Hiya again folks
                    I managed to get branded roller swingarm bearings for about half the price of Yamaha ones, the bearing code will be on the side of the old bearings if you still have them.
                    • D DTR+NSR
                      Walney-ReptilesW
                      Walney-ReptilesW
                      Walney-Reptiles
                      @DTR-NSR i dont have them no more there was nawt left of them anychance you may have old ones laying around to get numbers off?
                        @Walney-Reptiles you need linkage stuff or swing arm stuff?
                          Walney-ReptilesW
                          Walney-ReptilesW
                          Walney-Reptiles
                          @declan I need the linkage stuff
                          • Walney-ReptilesW
                            Walney-ReptilesW
                            Walney-Reptiles
                            Also can someone link me to the upgrade bearings for the headset on the 2002 yamaha dtr?
                              @Walney-Reptiles There are upgradable bearings?
                                Walney-ReptilesW
                                Walney-ReptilesW
                                Walney-Reptiles
                                @Calum well i say that what i mean is you can change the top bearing to taper bearings instead of the standard ring bearing
                                  @Walney-Reptiles Not without changing the the yokes/bearing cup.
                                  I done it cause I fitted USDs. But otherwise, no. Or I'm sure it could be done, but what would be the point?
                                    @Calum my dt is fitted with tapper bearings top and bottom with out modifications, tapper bearings are able to cope with greater loads so generally last longer.
                                    • D DTR+NSR
                                      @DTR-NSR Cool, hit the geezer up! I didn't know it was a thing.
                                      My DT was stolen and ramped. Forks bent, wheels bent, bearings in the head tube was fine. They are robust enough. Obviously Taper has its advantages.
                                      • Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        wrote on last edited by Walney-Reptiles
                                        #34
                                        Well i have made some more orders list below
                                        Head race bearings
                                        Linkage bearings and bushes
                                        Rear swing arm bearings
                                        Frunt wheel and Rear wheel bearings
                                        in total Β£186.59
                                        Heres a list with everythink i have bought since i started the project back in july including the above..
                                        Athena 125cc cylinderhead kit Β£429.95
                                        All bearings in engine (SimplyBearings.co.uk) one from pjme Β£128.09
                                        All bearings on frame and wheels (coming from ebay.co.uk) Β£186.59
                                        Athena full oilseals (from ebay.co.uk) Β£33.95
                                        Athena Full gasket set (from ebay.co.uk) Β£29.99
                                        MSP (replacment bits for inside engine that i lost) Β£45.48
                                        Sub Total Β£854.05 SO FAR
                                        I estimate there will be atleast Β£600-Β£700 more ontop left to be spent before it is complete
                                        M 1 Reply Last reply
                                          Oh sweet bud. Sounds very expensive, but if its a job worth doing it's worth doing right.
