  4. 2003 Yamaha Dt125R Project
68 Posts 14 Posters 19.1k Views 1 Watching
  • M
    M
    mhbikesnbits
    Looks very well I like it
      @Walney-Reptiles it’s so nice!
      Walney-ReptilesW
      Walney-ReptilesW
      Walney-Reptiles
      @declan @NINJA @mhbikesnbits
      Cheers guys! Its been a long time coming, most of the time it took me to rebuild it was waiting for parts from MSP but least i know the engine is 100% good to go, just need to get the rest of the bike going now.
        Very smart 😃
        • Walney-ReptilesW
          Walney-ReptilesW
          Walney-Reptiles
          Hiya again folks
          So i have some good news i have started at a garage as a welder / fabricator repairing rotten sills on vans, cars, buses etc....
          My boss is kind enough to let me redo and weld new nuts and other work to all my parts before he sends it all off for powder coating, i have one question regarding the suspention linkage and bushes etc... I dont want to pay £355 for genuine yamah bearings and oil seals etc... so i want to know what size bearings i can get as a replacment instead of the standard roller bearings i wanna use ball bearings instead anyone know what size bearings i will need?
            Hiya again folks
            I managed to get branded roller swingarm bearings for about half the price of Yamaha ones, the bearing code will be on the side of the old bearings if you still have them.
            • D DTR+NSR
              Walney-ReptilesW
              Walney-ReptilesW
              Walney-Reptiles
              @DTR-NSR i dont have them no more there was nawt left of them anychance you may have old ones laying around to get numbers off?
                @Walney-Reptiles you need linkage stuff or swing arm stuff?
                  Walney-ReptilesW
                  Walney-ReptilesW
                  Walney-Reptiles
                  @declan I need the linkage stuff
                  • Walney-ReptilesW
                    Walney-ReptilesW
                    Walney-Reptiles
                    Also can someone link me to the upgrade bearings for the headset on the 2002 yamaha dtr?
                      @Walney-Reptiles There are upgradable bearings?
                        Walney-ReptilesW
                        Walney-ReptilesW
                        Walney-Reptiles
                        @Calum well i say that what i mean is you can change the top bearing to taper bearings instead of the standard ring bearing
                          @Walney-Reptiles Not without changing the the yokes/bearing cup.
                          I done it cause I fitted USDs. But otherwise, no. Or I'm sure it could be done, but what would be the point?
                            @Calum my dt is fitted with tapper bearings top and bottom with out modifications, tapper bearings are able to cope with greater loads so generally last longer.
                            • D DTR+NSR
                              @DTR-NSR Cool, hit the geezer up! I didn't know it was a thing.
                              My DT was stolen and ramped. Forks bent, wheels bent, bearings in the head tube was fine. They are robust enough. Obviously Taper has its advantages.
                              • Walney-ReptilesW
                                Walney-ReptilesW
                                Walney-Reptiles
                                wrote on last edited by Walney-Reptiles
                                #34
                                Well i have made some more orders list below
                                Head race bearings
                                Linkage bearings and bushes
                                Rear swing arm bearings
                                Frunt wheel and Rear wheel bearings
                                in total £186.59
                                Heres a list with everythink i have bought since i started the project back in july including the above..
                                Athena 125cc cylinderhead kit £429.95
                                All bearings in engine (SimplyBearings.co.uk) one from pjme £128.09
                                All bearings on frame and wheels (coming from ebay.co.uk) £186.59
                                Athena full oilseals (from ebay.co.uk) £33.95
                                Athena Full gasket set (from ebay.co.uk) £29.99
                                MSP (replacment bits for inside engine that i lost) £45.48
                                Sub Total £854.05 SO FAR
                                I estimate there will be atleast £600-£700 more ontop left to be spent before it is complete
                                M 1 Reply Last reply
                                  Oh sweet bud. Sounds very expensive, but if its a job worth doing it's worth doing right.
                                    Walney-ReptilesW
                                    Walney-ReptilesW
                                    Walney-Reptiles
                                    @Calum I agree there mate, I will be getting a new carb ANY advice on carbs? im not after the cheapest one or the most expensive one also i will be getting one of them zeeltronic CDI's for my bike but id like to know if anyone on here has set one up? currently i have the 3RM-20 cdi units would the zeeltronic CDI replace that? i also use the PV System.
                                    clawsC 1 Reply Last reply
                                    • Walney-ReptilesW
                                      Walney-ReptilesW
                                      Walney-Reptiles
                                      So i have Just ordered some more bits...
                                      Yamaha WR125X Radiator With 12v fan (Im going to fabricate my own mounts for this so dont worry if you think it wont fit ordered this because my DTR one is Crap and the wr one was only £32 with free postage)
                                      Also ordered
                                      a second Rad fan witch was £18
                                      DT125R Stainless Engine mounting allen bolts
                                      Just an extra note im going to cut the elbow off the bottom of the radiator and spin it to point the correct way 🙂
                                      • Walney-ReptilesW
                                        Walney-ReptilesW
                                        Walney-Reptiles
                                        Well i have had some Post Today 🙂
                                        Swingarm bearings and bushes and seals aka service kit
                                        Linkage bearings and bushes and seals aka service kit
                                        Head race Taper bearings top and bottom
                                          M
                                          M
                                          morty
                                          @Walney-Reptiles where’d you get the linkage kit from pal?
