  4. 1988 bike
1988 bike
139 Posts 9 Posters 69.3k Views 1 Watching
  • O Offline
    O Offline
    Will not need to though if it's an 88 engine? Just need to make sure crank is correct for stroke, will check part nos to be sure.
    • O oldman
      @oldman If it was running a 3MB and you put a 3BN barrel on it, the stroke will be too long. Is it the crank, is it the rod? I don't know. But the stroke is definitely different. So you will want to make sure you have clearance.
      • O Offline
        O Offline
        Checked fowlers for part no, con rod for 88 listed as separate item, later years checked a(89 and 1990) and shows discontinued with no part nos? Have ordered a genuine 88 one to be sure but any info you have useful? Original barrel was already 1.75 over hence the replacement
        • O Offline
          O Offline
          It's definitely an 88 bike and engine, the barrel was consistent with engine and I did have a spare 3mb barrel but sourced like for like. Cant be sure con rod in engine is correct hence ordering correct one from fowlers. Could be whole crank differs from later bikes but don't know (yet) will check clearances as built, lucky to find a matching barrel to be honest
          • O oldman
            @oldman Yeah this.
            The manual specifies both the bore and stroke for the 3BN, I'm sure. I don't have it to hand.
            It is so minor I doubt it'll be too much of a problem. Powervalves are not interchangeable though.
            As said, doubling up on base gasket will do the trick. My worry is that the con rod is designed to stretch and compress, how close will it be at 12k RPM is anyones guess!
            O 1 Reply Last reply
            • O Offline
              O Offline
              Have the original powervalve fortunately, the manual is. 4 or. 04 difference I think from memory, Will be checking when assembling .
              D 1 Reply Last reply
              • O oldman
                DTR+NSR
                My understanding is the 1988 has the BN barrel and slightly longer stroke 0.5mm or something. 88 on wards they had slightly bigger bore and shorter stroke. Think if you mix and match parts you can end up with a 135cc or similar.
                  @oldman Yeah this.
                  O Offline
                  O Offline
                  @Calum said in 1988 bike:
                  @oldman Yeah this.
                  Hello Calum,What's the difference with the powervalve? Have measured and dry assembled and seems no different than one that came with bike, bar original has no grooves for seals and diamond style pulley shaft on end? Frame back but waiting for rack, grab rail, footrest hangers, suspension spring, etc.
                  • O oldman
                    @oldman Yeah this.
                    @oldman I must be thinking 4FU and 3MB.
                    One of them didn't fit.
                    • O Offline
                      O Offline
                      OK, thanks Calum. Replacement shock arrived and it's worse than the one I need to replace sadly. Lower ball joint corroded and worn and corrosion on plunger shaft has damaged the seal, very little damping going on. Will keep looking for a decent one.
                      CalumC D 2 Replies Last reply
                      • O oldman
                        @oldman FFS :@
                        • O oldman
                          dan28
                          @oldman said in 1988 bike:
                          look for a shock from a newer bike they have a white spring an fit on the 89 model
                          • O Offline
                            O Offline
                            Finally got a decent shock, waiting for powdercoating to return (have frame back though)so I can start rebuild. Seller of faulty shock not responded yet to return for refund, but covered via PayPal. Looked at getting a new indicator switch gear assembly and they are over £150. Put that on the wish list with everything else. Photos will be posted when there is something to show!
                            • O Offline
                              O Offline
                              Powdercoating back bar 2 items that should be here later this week, now where did I leave the assembly instructions????20190623_231148-460x818.jpg
                                Haha that looks fantastic!
                                • O Offline
                                  O Offline
                                  #36
                                  Thought I had most of it but still missing plenty of bolts and fixings. Returned some of the plating, looked bad to be honest. On top of that rats have chewed the brake pipes on my van so that's being recovered on a flatbed truck tomorrow, revenge for shooting one. Started off with the abs light coming on, took to garage and sensor wire cut. Went to take it for repair and no brakes at all, other rear sensor wire chewed and brake fluid squirting out of chewed hose. How lucky am I
                                  • O Offline
                                    O Offline
                                    Progress has been slow, mainly due to the weather this weekend. But important parts are coming back so I will try and press on (especially if it rains!) Attended vjmc show Sunday then a decent ride with both the red and white dt's, my blue 125mx and an rd350lc. I can still taste the 2 stroke oil being at the back (I was riding the 125mx). Covered approx 70 miles without mishaps, bit I so want a rd350, sounds brilliant.20190701_195432-460x818.jpg 20190701_195442-819x461.jpg 20190701_195501-819x461.jpg
                                    • O Offline
                                      O Offline
                                      • O Offline
                                        O Offline
                                        Refurbed oil pump arrived back this morning, hard to believe it's almost 31 years old, perfect job!
                                        Powdercoated spring collected yesterday as well, so can crack on a bit.
                                        • O Offline
                                          O Offline
                                          Reassembled shock ready for action
