  4. 1988 bike
1988 bike
139 Posts 9 Posters 67.8k Views 1 Watching
  • O oldman
    Have the original powervalve fortunately, the manual is. 4 or. 04 difference I think from memory, Will be checking when assembling .
    D Offline
    D Offline
    My understanding is the 1988 has the BN barrel and slightly longer stroke 0.5mm or something. 88 on wards they had slightly bigger bore and shorter stroke. Think if you mix and match parts you can end up with a 135cc or similar.
      @oldman Yeah this.
      The manual specifies both the bore and stroke for the 3BN, I'm sure. I don't have it to hand.
      It is so minor I doubt it'll be too much of a problem. Powervalves are not interchangeable though.
      As said, doubling up on base gasket will do the trick. My worry is that the con rod is designed to stretch and compress, how close will it be at 12k RPM is anyones guess!
      O Offline
      O Offline
      @Calum said in 1988 bike:
      @oldman Yeah this.
      Hello Calum,What's the difference with the powervalve? Have measured and dry assembled and seems no different than one that came with bike, bar original has no grooves for seals and diamond style pulley shaft on end? Frame back but waiting for rack, grab rail, footrest hangers, suspension spring, etc.
      • O oldman
        @oldman Yeah this.
        @oldman I must be thinking 4FU and 3MB.
        One of them didn't fit.
        • O Offline
          O Offline
          OK, thanks Calum. Replacement shock arrived and it's worse than the one I need to replace sadly. Lower ball joint corroded and worn and corrosion on plunger shaft has damaged the seal, very little damping going on. Will keep looking for a decent one.
          CalumC D 2 Replies Last reply
          • O oldman
            @oldman FFS :@
            • O oldman
              D Offline
              D Offline
              dan28
              @oldman said in 1988 bike:
              look for a shock from a newer bike they have a white spring an fit on the 89 model
              • O Offline
                O Offline
                Finally got a decent shock, waiting for powdercoating to return (have frame back though)so I can start rebuild. Seller of faulty shock not responded yet to return for refund, but covered via PayPal. Looked at getting a new indicator switch gear assembly and they are over £150. Put that on the wish list with everything else. Photos will be posted when there is something to show!
                • O Offline
                  O Offline
                  Powdercoating back bar 2 items that should be here later this week, now where did I leave the assembly instructions????20190623_231148-460x818.jpg
                    Haha that looks fantastic!
                    • O Offline
                      O Offline
                      #36
                      Thought I had most of it but still missing plenty of bolts and fixings. Returned some of the plating, looked bad to be honest. On top of that rats have chewed the brake pipes on my van so that's being recovered on a flatbed truck tomorrow, revenge for shooting one. Started off with the abs light coming on, took to garage and sensor wire cut. Went to take it for repair and no brakes at all, other rear sensor wire chewed and brake fluid squirting out of chewed hose. How lucky am I
                      • O Offline
                        O Offline
                        Progress has been slow, mainly due to the weather this weekend. But important parts are coming back so I will try and press on (especially if it rains!) Attended vjmc show Sunday then a decent ride with both the red and white dt's, my blue 125mx and an rd350lc. I can still taste the 2 stroke oil being at the back (I was riding the 125mx). Covered approx 70 miles without mishaps, bit I so want a rd350, sounds brilliant.20190701_195432-460x818.jpg 20190701_195442-819x461.jpg 20190701_195501-819x461.jpg
                        • O Offline
                          O Offline
                          • O Offline
                            O Offline
                            Refurbed oil pump arrived back this morning, hard to believe it's almost 31 years old, perfect job!
                            Powdercoated spring collected yesterday as well, so can crack on a bit.
                            • O Offline
                              O Offline
                              Reassembled shock ready for action
                                When I asked if the pump could be refurbished I was told it wasn't possible! I think he just didn't want the work!
                                • O Offline
                                  O Offline
                                  #42
                                  Hes done all of mine, always come back like new, said there was loads of crud inside this one. Comes back with genuine Yamaha gasket and vent screw seals. Its peace of mind that I will not have to worry about it.
                                  N 1 Reply Last reply
                                  • O oldman
                                    N Offline
                                    N Offline
                                    @oldman Nothing beats some super shiny parts to bolt back on. :grinning_face_with_smiling_eyes: :winking_face: :grinning_face_with_smiling_eyes: :face_with_stuck-out_tongue_winking_eye:
                                    • O Offline
                                      O Offline
                                      Engine has entered the building!, shot blasted cases and 2 pack paint on side covers, wont even get my hands dirty fitting!20190709_141441-819x461.jpg 20190709_141423-819x461.jpg
                                      • O oldman
                                        N Offline
                                        N Offline
                                        #45
                                        @oldman Looks awesome dude, are the cases and head bare metal and did you spray the covers yourself???
                                        O 1 Reply Last reply
                                        • N NINJA
                                          O Offline
                                          O Offline
                                          @NINJA head prepared by me, sprayed and laquered, cases bare, side cases 2 pack professionally done
