  4. Dt200 engine build
Dt200 engine build
13 Posts 6 Posters 3.3k Views
  • SamRatBoyS
    SamRatBoyS
    SamRatBoy
    Hey there all. I've been wanting to fit a Dt200 engine into my for a few years now and so when I saw a reasonable priced seized 200 bottom end on eBay I couldn't resist. I however couldn't find a reasonable priced Wr200 barrel with powervalve nor a Dt200 barrel. Eventually I spotted a Sdr200 cylinder on the bay complete with power valve (sadly it doesn't have boost ports like the we 😞 ) and purchased it. Needless to say the crank will be sent for a rebuild. My question is does anyone know if the taper on the flywheel side of the Dt200 crank is the same as the Dt125? Im having trouble finding a 200 stator, flywheel and cdi. I'm hoping at first to be able to run it with the 125 stator and cdi. I know it won't be running at optimum but can anyone confirm if this won't work or will be harmful to the engine or have any ideas. Thanks, Sam
    • ChallengerC
      ChallengerC
      Challenger
      3ET/2YY DT200R stator and flywheel are exactly the same as in DT125R. Only difference is part number stamped on the flywheel.
      SamRatBoyS 1 Reply Last reply
      • ChallengerC Challenger
        SamRatBoyS
        SamRatBoyS
        SamRatBoy
        @Challenger excellent news 🙂 thanks for the reply
        • autovictorA
          autovictorA
          autovictor
          is it possible to fit the re/x stator on the dt/wr 200 crankshaft? does anybody did the 200 conversion on a re/x?
          • autovictorA autovictor
            @autovictor The RE/X Flywheel goes on reverse to that of the DTR and has the starter motor teeth.
            So at a guess, I'd say it's not possible without modifications. Woodruff key will be in the wrong place and taper of the crank will be wrong.
            • O
              O
              Joining the 200 club! Be a while though, got my holiday to pay for first!
              ChallengerC 1 Reply Last reply
              3
              • O oldman
                ChallengerC
                ChallengerC
                Challenger
                @oldman nice to see that cylinder on the forum 😀
                • pedrobatista10P
                  pedrobatista10P
                  pedrobatista10
                  guys how much cost 3xp barrel at the moment? saw one on ebay from greece for 215€ ( need to be repaired i guess)
                  • pedrobatista10P pedrobatista10
                    ChallengerC
                    ChallengerC
                    Challenger
                    @pedrobatista10 there are really a lot of variables when it comes to the condition of a barrel
                    • pedrobatista10P
                      pedrobatista10P
                      pedrobatista10
                      @Challenger this one, i think its the only one for sale on ebay.
                      https://www.ebay.com/itm/yamaha-wr200-cylinder-barrel-barel-jug-dt-4bf-3xp-wr-200-wr200rd-dt200-dt200wr/143238727899?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D004f0a5e233846359e4fc32bca6e4f96%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D143238727899%26itm%3D143238727899%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6ccdbf0e-46a6-11ea-a919-74dbd18033a0|parentrq%3A0bfd5ebd1700a861903b0e28ffee23c0|iid%3A1
                        No way, at that price I'd give it a miss!
                        You definitely want the valve & head.
                        The crack needs welding, it'll need replating. I've seen entire engines go for not much more than that.
                        Not worth the gain in my opinion.
                        • pedrobatista10P
                          pedrobatista10P
                          pedrobatista10
                          look at this beautiful kit, not cheap but looks very good
                          https://www.olx.pt/anuncio/kit-cilindro-200-para-yamaha-dt-125-r-dtr-tzr-rz-IDEht5T.html
                            Missing the head. If that had the head it would be more of a goer.
