Rear wheel
If you have access to a machinist, the cost is minimal. But it all adds up. Hours on the lathe and precise measurements were necessary to get all the stars to align. I had to shim the rear sprocket to get it to fall inline with the front.
When I took the bike in to have the tyres replaced. They omitted the shims and the rear sprocket carrier bearing collapsed shortly after. So it does have to be on point.
And in summer i go to machine shop for summerwork so i can make them afterwork.
And are the rims same size if you can give some measurements of the parts?
How about the speedo?
Does the ride quality increase
@jonne123 You need adaptors for the brakes!
You have to centralise the brakes over the disc, otherwise one side of the pad will just bind against the disc.
It's a lot of work. The easiest thing to do is just get decent tyres on a DTR setup,
I will say right now mate, the most fun I've had on my DTR is in bog stock trim.
I absolutely adored the handling of it stock, or lack there of.
My SM DT just grips and stops on a dime and that's really safe, but doesn't make for much fun.
Now I love my setup, wouldn't change it for the world. I'm just saying, grass isn't always greener.
By far the best thing you can do, get some dual sport tyres (so you can still do light off roading). Stiffen that front suspension unit up. get a pipe on it and a 3MB head if it hasn't got it already and and a Zeeltronic ignition system.
You bike will be absolute hoon to ride and will pack a little punch too.
Otherwise, I'd sell that DTR and get a better bike like an Aprilia MX125. Trust me, if I had my time again, that's exactly what I'd do.
With your input, this post could be even better π
