  4. So Close!...
So Close!...
1.1k Posts 26 Posters 498.9k Views
    Ptsch, even with my 170 kit my DTR is nailed more RPMs than that.
    Spa Motorcycle Cheltenham rebuild DTR cranks too.
      @HOTSHOT-III
      My conrod is bent/deflected to one side. Result of having a wrong pilot jet causing missffires and knocking for to many thousand miles (& head gaskets) to recall. It resulted in the flywheel side of the piston having 1mm of play between gudgeon/wrist~pin and the piston. A little bit slappy!! 😐 …
      The crank I bought looks good and was an absolute bargain @ £30 or so, but I’m very paranoid about getting the next motor right. It looks like a new conrod was fitted very recently…
      Did Arnold’s used to be a scooter place??…
      #622
      @SpookDog If you're building up a bottom end I'd just get the crankshaft rebuilt and be done with it to be honest, either that or buy a brand new trued and ready to fit Top Racing/Jasil crank from PJME which cost about the same as a crank rebuild but offer the advantage of completely unworn surfaces where the main bearings are an interference fit (these eventually wear out leading to the crank journals spinning inside the main bearing inner races). I fitted one of these to the DTR engine I rebuilt with Athena top end etc last year, it fitted well and is still running well as far as I know.
      Something goes wrong with your £30 one it's going to cost you more sorting it out and it's another round of engine rebuilding (and not necessarily your fault as you're at the mercy of whoever built the crank and whether they used a good or budget rod kit). You could end up wrecking a decent barrel or a set of crankcases, both of which are getting increasingly difficult to get hold of so IMO this is false economy. I've known DTR crankshafts to last 35k+ miles even when abused by 17-year-olds through 3 or 4 top end meltdowns (ahem) so it's worth spending some time and money getting the bottom end spot on.
      Never been to Arnold's but he comes highly recommended. I'd talk to all 3 TBH, PJME, Grampians and Arnolds and see what they all offer. I know PJME do a ParcelForce collection/return service for crank rebuilds and rebores. Also try Jim Bailey at RoadRunners Motorcycles in Stoke-on-Trent, he offers a complete DTR engine rebuild service if you can ship your engine to him.
      S 2 Replies Last reply
      • HOTSHOT IIIH HOTSHOT III
        @HOTSHOT-III
        If I’d known before that a decent crank was buyable for £150 I would of done so,
        I’m prolly just being paranoid. I’ve had so many problems getting the bike to the proper place...
        2 years to suss out the proper jetting for the carb type! So embarrassing. I just put in a new replacement 25 pilot jet yesterday (I still haven’t found a uk seller for genuine Mikuni 25 jets!) and the bike feels like a totally different animal. Clean crisp revs throughout the range. Starts without choke and ticks over so much steadier…
        It might sound stupid but I didn’t realise how wrong it was until I’d ridden a dtr that is running true. Just because it was an improvement on the previous try I thought it was okay. I had a genuine 25 pilot in there but it was partially blocked with solidified crud, then I must of overcooked it with the cleaning wire!…
        I probably have cause to be paranoid! What with my existing learning curve looking like a clutch spring! 🃏
          @HOTSHOT-III
          You were right, I had a closer look at the crank. The inside of the small end has ‘damage’ to it. I guess I’m gonna have to save up a couple hundy pennies for a crank before dreaming about new rims 🙂 Them’s the licks…
          I’m seriously thinking about getting the tzr up and running. MoT it and use it, so as I can tear into the Dtr without time constraints. Get the frame dipped and painted and learn how to make a loom! It needs it. I want it to be a righteous little tear~about someday ☠️
          3
            @HOTSHOT-III
            @SpookDog Sounds like a winter project to me 🤣 For now you ought to just enjoy it.
              @HOTSHOT-III
              #626
              @SpookDog Shame about the crank but at least you found out the easy way 👍
              We're probably on for another heatwave after all this rain so keep enjoying the DTR for another couple of months and start stockpiling parts for doing a frame-off nut and bolt rebuild over Winter. I'd be interested to see the TZR project coming along though, always rated them just because IMO the DTR engine platform is one of Yamaha's greatest achievements. Nearly 40 years now since it debuted in the original TZR125 and still being manufactured under licence!
              BTW have you tried Allen Performance for Mikuni Jets? https://www.allensperformance.co.uk/shop/
                @HOTSHOT-III
                Wicked resource! But they only start at .30
                I need a .25
                .225 are the most common Dtr jet
                  @HOTSHOT-III
                  I need a .25
                  #628
                  I’ve just found a really wicked way of seating tubeless tyres onto the rims!
                  Unscrew the pfieffer (sp?) valve and give a quick squirt of easy start into the valve (I used the top & straw off a wd40 can) only half a second!! Then using a blow torch at arms length, light the end of the valve. There’s a loud pop! as the bead seats, then a long hiisssssssss! as the excess pressure vents through the hollow valve! It’s a bit Leary but it works a treat 😎
                  Beads settled and tyres inflated, just trying the test of time now (till morning 🤞)
                  Showcasing the gates I spent the last month making for my Sis! Recycled crap and £20 worth of fence post wood! Just doing my JC thing 😇 (carpentry, burning bush & beer!!)
                  Hence why I’ve not gotten shnit done on the bike…
                    What are these wheels for?
                    MadGyverM 1 Reply Last reply
                      #630
                      @SpookDog Gates look ace, very well made 👍
                      I was cycling the other day, a wasp got stuck underneath my helmet and stung me about 6 times in the time it took me to stop and take my helmet off and tread on the flying yobbo. So assuming I can locate where they hang out, I'd be most grateful if you don't use up all the Easy Start 🔥
                        MadGyverM Offline
                        MadGyverM Offline
                        MadGyver
                        Probably TZR250 2MA.
                          I meant, are they for you DT or are they for another project?
                            #633
                            @HOTSHOT-III
                            I usually end up with them between my shoulder blades! It’s happened a few times in the last two summers! They must get sucked back there on a vortex and I end up doing ‘The Dance’ on the side of the road.⚡️☠️⚡️
                            Tzr125rr (4HW) The 1994 one that used a 3vx 250 frame…
                            PS They stayed inflated as well! It’s a handy technique I found on YouTube. I just refined it a little 🙂 …
                              @HOTSHOT-III
                              I need a .25
                              markus.wM Offline
                              markus.wM Offline
                              #634
                              @SpookDog try KMT products limited. British made jets by a Northamptonshire company. Top quality too. Unlike the Chinese copies and they start at .10.
                              https://www.ebay.co.uk/itm/273888042871?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=RUUIcrapSsS&sssrc=4429486&ssuid=7ztfcrwyt6w&var=573711906965&widget_ver=artemis&media=COPY
                              • OllieDTRO Offline
                                OllieDTRO Offline
                                OllieDTR
                                Hi guys sorry Abit off topic here
                                Just picked up a dtr from my mate, it had the ktm style front light on it, the wires are
                                Green = Ground
                                White = High beam
                                Blue = Low beam
                                Brown = Sidelight
                                I can get sidelight working when ignition key is turned and also the normal beam headlight but the switch doesn’t do anything, the wires have previously been cut, I’m just wondering if anyone has a picture of the wiring colours for headlight and the switch the switch looks like a Newer 2003+ one
                                I’ll put some pictures up if it lets me
                                Cheers !
                                • OllieDTRO Offline
                                  OllieDTRO Offline
                                  OllieDTR
                                  Here is the wires for ktm style headlight what ones would I connect for it all to work above is the wires that’s at the front of the bike
                                  Not use to all this cut wires but I don’t want to get a new loom just for 4 wires for headlight lolalt text
                                  • OllieDTRO OllieDTR
                                    @OllieDTR
                                    On my dtr125
                                    Black: earth
                                    Green: headlight
                                    Yellow:headlight
                                    Blue/Red: sidelight
                                    Don’t remember what colour is main or dip, just experiment 🙂 …
                                      @OllieDTR
                                      On my dtr125
                                      Black: earth
                                      Green: headlight
                                      Yellow:headlight
                                      Blue/Red: sidelight
                                      Got a new crank ordered from PJME. Just waiting on it now. Need to get a bolt lug welding on to the flywheel side of the crank casing and I’ll be good to start building this thing…
                                        #639
                                        Waiting on the flywheel puller now. There’s some noise from that sides bearing, maybe. It might be the starter clutch ring though. I don’t have any experience of elecy start lumps. So I want to remove the flywheel and starter clutch-ring stuff and see how it sounds without all that gumpf.
                                        There’s no (up/down) movement in the crankshaft apart from a bit of side to side, which I can’t say I remember ever seeing before. I don’t know if that’s normal?…
                                          Crankshaft? Or Connecting rod?
                                          There should be some side float, no up/down movement.
                                          The starter bendix will make some noise, but otherwise it should be silent.
