    What are these wheels for?
    MadGyverM 1 Reply Last reply
      I’ve just found a really wicked way of seating tubeless tyres onto the rims!
      Unscrew the pfieffer (sp?) valve and give a quick squirt of easy start into the valve (I used the top & straw off a wd40 can) only half a second!! Then using a blow torch at arms length, light the end of the valve. There’s a loud pop! as the bead seats, then a long hiisssssssss! as the excess pressure vents through the hollow valve! It’s a bit Leary but it works a treat 😎
      Beads settled and tyres inflated, just trying the test of time now (till morning 🤞)
      Showcasing the gates I spent the last month making for my Sis! Recycled crap and £20 worth of fence post wood! Just doing my JC thing 😇 (carpentry, burning bush & beer!!)
      Hence why I’ve not gotten shnit done on the bike…
      #630
      @SpookDog Gates look ace, very well made 👍
      I was cycling the other day, a wasp got stuck underneath my helmet and stung me about 6 times in the time it took me to stop and take my helmet off and tread on the flying yobbo. So assuming I can locate where they hang out, I'd be most grateful if you don't use up all the Easy Start 🔥
        MadGyverM
        MadGyverM
        Probably TZR250 2MA.
          I meant, are they for you DT or are they for another project?
            #633
            I usually end up with them between my shoulder blades! It’s happened a few times in the last two summers! They must get sucked back there on a vortex and I end up doing ‘The Dance’ on the side of the road.⚡️☠️⚡️
            Tzr125rr (4HW) The 1994 one that used a 3vx 250 frame…
            PS They stayed inflated as well! It’s a handy technique I found on YouTube. I just refined it a little 🙂 …
              Wicked resource! But they only start at .30
              I need a .25
              .225 are the most common Dtr jet
              #634
              @SpookDog try KMT products limited. British made jets by a Northamptonshire company. Top quality too. Unlike the Chinese copies and they start at .10.
              https://www.ebay.co.uk/itm/273888042871?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=RUUIcrapSsS&sssrc=4429486&ssuid=7ztfcrwyt6w&var=573711906965&widget_ver=artemis&media=COPY
              • OllieDTRO
                OllieDTRO
                OllieDTR
                Hi guys sorry Abit off topic here
                Just picked up a dtr from my mate, it had the ktm style front light on it, the wires are
                Green = Ground
                White = High beam
                Blue = Low beam
                Brown = Sidelight
                I can get sidelight working when ignition key is turned and also the normal beam headlight but the switch doesn’t do anything, the wires have previously been cut, I’m just wondering if anyone has a picture of the wiring colours for headlight and the switch the switch looks like a Newer 2003+ one
                I’ll put some pictures up if it lets me
                Cheers !
                • OllieDTRO
                  OllieDTRO
                  OllieDTR
                  Here is the wires for ktm style headlight what ones would I connect for it all to work above is the wires that’s at the front of the bike
                  Not use to all this cut wires but I don’t want to get a new loom just for 4 wires for headlight lolalt text
                  • OllieDTRO OllieDTR
                    @OllieDTR
                    On my dtr125
                    Black: earth
                    Green: headlight
                    Yellow:headlight
                    Blue/Red: sidelight
                    Don’t remember what colour is main or dip, just experiment 🙂 …
                      @OllieDTR
                      On my dtr125
                      Black: earth
                      Green: headlight
                      Yellow:headlight
                      Blue/Red: sidelight
                      Got a new crank ordered from PJME. Just waiting on it now. Need to get a bolt lug welding on to the flywheel side of the crank casing and I’ll be good to start building this thing…
                        #639
                        Waiting on the flywheel puller now. There’s some noise from that sides bearing, maybe. It might be the starter clutch ring though. I don’t have any experience of elecy start lumps. So I want to remove the flywheel and starter clutch-ring stuff and see how it sounds without all that gumpf.
                        There’s no (up/down) movement in the crankshaft apart from a bit of side to side, which I can’t say I remember ever seeing before. I don’t know if that’s normal?…
                          Crankshaft? Or Connecting rod?
                          There should be some side float, no up/down movement.
                          The starter bendix will make some noise, but otherwise it should be silent.
                            #641
                            Sorry, I posted this in the wrong thread. Meant to be in the Tzr forum…
                            I meant crank movement, only the tiniest bit 🙂 …
                            Bendix? Sounds like something Uri Geller would do in the bedroom! 😳 …
                            While I’ve gotten some free time I’m gonna tackle the water pump seal on the dtr. I’ve been meaning to for a while now. The oil has an opaque milky look to it where it’s been emulsified with the coolant.
                            I need the new seal I have for the tizzer now though. Luckily I’ve got a spare clutch casing with good pump seal, ect…
                              #642
                              One thing I’ve noticed from working on the Tzr are the handy bits of steel clip/bracketing that holds the wiring near the front sprocket in place. Even for the gearbox breather tube. There are loads of other guides and clips missing from my bike. I would really like to know where they all go so as I can try and replace them…
                              Anyone got ideas of how to find them out , short of doing a walk around a totally standard survivor bike?…
                                Are they not itemised on the exploading diagrams?
                                https://www.fowlersparts.co.uk/main/img/assemblies/large/016ee6130ef8ca51319e1cded43b55e0.png
                                As an example:
                                https://www.fowlersparts.co.uk/parts/4111561/tzr125-4fl1-1993-999-a/crankcase
                                  As an example:
                                  #644
                                  I’ve never looked specifically, but nothing has ever caught my attention before while looking. I’ll have to check…
                                  Damn this has gotten a lot worse than before!…
                                  That is some pusstulant looking ‘goo~oil’!!…
                                    #645
                                    Job done. New seal, new gasket and new oil. Just gotta wait for and see now…
                                    Buttery gearchanges now, especially since oiling the clutch cable as well. Feels like an even newer, different bike! Feels like the rolling resistance is better as well, or I’m imagining it! Ever way it’s a plus 🙂 …
                                      Well…
                                      When I fitted the new clutch casing I omitted the oil pump. I never realised that the bottom screw bolt isn’t blind like the top one. It goes straight through to the gearbox for some reason. Ended up with a boot and a back tyre/disc full of oil. Won’t make that mistake again 🙂 …
                                        Engine's okay though? Just leaking gearbox oil through the bolt hole! Doh!
                                          #648
                                          Yep, the 2T pump lower 4mm screw/bolt hole goes all the way through to the nylon cog on the inside…
                                          Plugged it with a screw/bolt…
                                          Oil & brakes? Who would of guessed? 😐 …
