  4. So Close!...
So Close!...
1.1k Posts 26 Posters 665.9k Views
    I seriously can't get over how much you ride lmao. I don't think I've done 30k miles in all of the vehicles I've owned.
    I still need a gudgeon pin for an Athena 170 piston. It’s 16mm x 56mm. The only one I can find is 16 x 57mm…
    If anyone has put a new piston in their Athena kit and still has the old pin please let me know. I can’t do any more to my build till I get one 😐 …
    Cheers Peeps!…
    CalumC MadGyverM 2 Replies Last reply
      Cheers Peeps!…
      @SpookDog I only recently threw away an Athena 170 gudgeon pin that only saw a few hundred miles on it 😮
        Cheers Peeps!…
        MadGyverM
        MadGyverM
        MadGyver
        Cheers Peeps!…
        Why don't you take the 16x57 and machine off 0.5mm from each side?
        I remember the pin from the kit has a little play when installed with the circlips,maybe there is space for that 1mm.
          #764
          Well f@nk you very much! Wasteful Torrie! 🙂 …
          @MadGyver
          My plan B! 😜 …
          I’ve got one ordered earlier today, once I found out my siss’s card worked. She’s a fuxin heroin when it comes to keeping me afloat!
          It looks like there is enough room to fit the 57mm pin, I’m just not clued up on heat expansion & the like. I can just imagine it popping off a curclip when it comes up to temp! 🫤 …
          Edit: I forgot to ask about Athena replacement piston rings. Best place to get them? I understand that they’re specific to these kits as they’re 1mm thick/thin? Seems churlish not to fit new ones if they’re available and not astronomicaly priced …
            @MadGyver
            My plan B! 😜 …
            The spacer that I have on the primary drive side of the crank has a groove machined into it. Does the groove side go into the crank seal?…
            The others I’ve done before haven’t had the groove…
            • MadGyverM
              MadGyverM
              MadGyver
              #766
              @SpookDog
              Can you post a picture,I don't remember groove on mine.
              • MadGyverM MadGyver
                @SpookDog
                #767
                @MadGyver
                You can see that it’s been used either way round. I was just wondering what the reason is? If it aligned with the seal I could understand, but the wear pattern shows it doesn’t…
                Actually, saying that! It looks like they’re not symmetrical! Strange! 🤔
                  @MadGyver
                  #768
                  Now I’m wondering if it’s original to the Dtr? It looks like it was used in a different engine, from the wear on one side to the other!
                  I don’t have another one kicking around that I know of. I’d like to know the measurements of a proper one so I can compare. It did skim off a sliver of the seal when I tapped it in. I though it was because it was a NOS seal and a bit hard. Guess I could of been wrong…
                  Edit: then again someone could of just tapped the seal in too far, or not enough one of the times! Arrggghhhhh!!! 🤪
                    #769
                    Oh well, one thing that I can say with absolute conviction is: don’t buy new old stock seals trying to save money! 😉
                    A 35 year old seal in the bike, is worth many, many more than in the bush. They age better in their natural environment 👍 …
                    • MadGyverM
                      MadGyverM
                      MadGyver
                      #770
                      @SpookDog
                      There is no reason for that groove there,no gain in lubrication or anything else. It's a spacer for seals. It must be from a wornout seal.
                      I had something similar on the spacer that seats the seal at the external chain sprocket. It looked like factory groove.
                        @SpookDog
                        #771
                        @MadGyver
                        Sorry bud, I disagree. I know, and have had, what you’re talking about. This isn’t wear, it’s machined. It’s a perfect V.
                        It’s just 1 not 2 like ‘normal’ wear would be?
                        With the new (nitrile?) seal in place flush with the casing the groove lines up with the outer lip. I think it actually gives a lot more surface area for the outer lip of the seal to mate up to…
                        I’ve only had the wear line on single lip seals, the sprocket spacer has been my experience as well. Now I’m wondering!…
                        I just can’t get over the amount of ‘curve balls’ this bike has given me! The learning curve has been like climbing K2! 😳
                        I do appreciate the input though, please let me know your thoughts!…
                          @MadGyver
                          @SpookDog I suspect there may be a correct way to put it in.
                          Part Number 25.
                          Can get a new one in Titanium 😉
                          https://titanclassics.com/product/titanium-front-sprocket-spacer/
                          • D
                            DTR+NSR
                            It's a wear groove, seen it many times on cranks etc. your lucky on the DT it's a removable bush/sleeve, that can be replaced. I'd turn it so the seal is running on a smooth section of the sleeve.
                            • D DTR+NSR
                              @DTR-NSR
                              That is what I first thought, but it’s so perfect. Also it’s a double lipped seal so there should be two. Can you understand where I’m coming from?…
                              When I saw it on the front sprocket spacer I thought it was wear. Now I’m starting to wonder. How much rubber would it take to wear into steel?!
                                @SpookDog I've updated my original post, I was having a hard time locating the part in question (being thick).
                                Anyway I think it's part number 25 you're after and it looks as though, no there should not be a lip there.
                                You can get a titanium replacement:
                                  @DTR-NSR
                                  HOTSHOT IIIH
                                  HOTSHOT IIIH
                                  #776
                                  @SpookDog I agree it looks machined, no idea what it's doing there but you can see how the crank seal lips have marked a wider track next to it on both sides, obviously at some point someone has rebuilt the engine and flipped the spacer to have a fresh surface running in their new crank seal.
                                  Be that as it may, in these kinds of situations where a hard material runs against a soft material, it's usually the harder material which experiences the most wear because small fragments of the hard material embed themselves in the soft material and then behave like boulders stuck in the bottom of glaciers which is what formed today's mountain ranges as they moved slowly downhill. That's why if you go looking for an aluminium 3ET DT200R swingarm for your DT125R, you have to be very careful not to buy one which has had the shock protector mudflap rubbing against it as this can make the back of the linkage pivot area dangerously worn. KTM also had this problem on their modern Enduro bikes leading to people gluing a 50p piece onto the back of the shock pivot mounting. I didn't want to trust JB Weld in an area exposed to lots of mud and chain lube so I cut open the plastic sleeve from inside a reel of sticky labels and zip tied it in place.
                                  Ti is a nice thought but I'd be wanting to look at its material properties, suitability for running against rubber etc. I think you can still get the OEM one from Fowlers for reasonably cheap.
                                  • HOTSHOT IIIH HOTSHOT III
                                    #777
                                    @HOTSHOT-III
                                    It’s weird no? I’ve flipped them over myself. It looks like the (first?) time it was fitted with the groove inwards they put the seal in to far, instead of being flush with the casing. I’ve not seen one with a groove before. I’m guessing it’s an aftermarket replacement…
                                    I have seen sprocket spacers with a groove that I assumed was wear. I’ve seen more that have ‘cut’ a shiny line in the rust that aren’t the same…
                                    Getting the lump together a bit today, mostly cause it’s not hissing down with rain & blowing crap everywhere! 🙂 …
                                      @HOTSHOT-III
                                      #778
                                      Fux! My bike has been running so luverly and crisp since the temp has dropped and it’s dried up a bit, but it’s developed a habit of stopping dead when I put it on the side stand (with a tiny bit of extra slope).
                                      I don’t have the plastic ‘pickup’ tube fitted to the pilot jet, cause it was picking up blobs of water before (thank you ethylene!) and fuxin up the low range of the throttle.
                                      This will have to be my memo to check the float height! Get some new clear 4mm tube Richy!! Do the overflow test!…
                                      I’ve kinda gotten used to having a reliable tickover!…
                                      It’s always something in this Life!!…
                                        @SpookDog Yeah my bike is running crisp in this weather also, the Cagiva has died a death, but the Yamaha is still going strong 🤣 But yeah, the idle can drop if left alone for a period of time. Doesn't help I'm running premix either as I find it typically fouls the plugs!
                                          This happens almost immediately! Don’t drop, just dies! I’ll have to do the level check where you use a clear pipe run from the overflow/drain up the side of the carb…
                                          Got my new 57 gudgeon pin but I’m worried about it being so snug. I’m wondering if it was a MM or so short to allow for expansion?…
