  4. Parts
Parts
15 Posts 5 Posters 1.8k Views
  • J Offline
    J Offline
    jonne123
    Is this nessesary i frogot to put this 3BN153170000
      Part 5?
      • J Offline
        J Offline
        jonne123
        Yes its that
        N 1 Reply Last reply
        • J jonne123
          Yes its that
          @jonne123 I would imagine that it's there for a reason, Yamaha deigned the bike that way, so I'd put it back in ASAP. 😉
          • NottsbikerN Offline
            NottsbikerN Offline
            What is it? Looks like a bush from this angle for the lower engine mount and if so needs to be kept in there
            • NottsbikerN Nottsbiker
              @nottsbiker Honestly don't know. Really unclear, but I think it's the dowels that sit between the crank cases.
                NottsbikerN Offline
                NottsbikerN Offline
                @calum yes I think its correct - think I've heard these referred to as a silent block in scooter terminology.
                Had to look at the engine out of my tdr125 and its the same set up in that as well 3SH / 3MB
                  @nottsbiker
                  It’s a steel tube (not unlike the casing dowels) with 2 skinny o-rings on it that goes between 2 steel ‘bushes’ (you can see the other sides bush and o-ring numbered 4 & 6 on the top right of pic) in the hole in the cases that the lower engine mount bolt slides through. The one just under the swing arm bolt...
                  On my engine the steel bushes are seated in rubber ‘cups’...
                  CalumC NottsbikerN 2 Replies Last reply
                    @nottsbiker
                    @spookdog Probably fit them then 🤣
                      @nottsbiker
                      NottsbikerN Offline
                      NottsbikerN Offline
                      @spookdog never taken them out to be honest but assume they are fitted for a good reason 🙂
                        @nottsbiker
                        Yeah, it’s so the outer bushes stay slightly prouder than the casing, so the rubber mounting can work. A bit like the metal tube inside headlight mounting rubbers. It gives the mount some wiggle room 🙂
                        • J Offline
                          J Offline
                          jonne123
                          If someone has the cases apart can you check that could you put that part 5 in by removing one bushibg or do i need to take the engine apart?
                            @jonne123 this is still unclear. Can you please upload a photo of the part you have. And why don't you just fit it. Why is this even up for debate? You have forgotten a component it's no biggie it literally takes an hour to disassemble and reassemble the DT engine so this should be a no brainer.
                            • J Offline
                              J Offline
                              jonne123
                              I would rather put it from outsude if i can. Its the matal tube with 2 o-rings
                              • J jonne123
                                @jonne123
                                You can put it in from the side.
                                Just lever out a bush, or put a screwdriver in one side and tap out the other...
                                You shouldn’t t need to split the cases. Just lift the engine up in the frame till you have access...
                                Edited for feckups 😐
