  3. Suspension
  4. Rear shock spring removal!
11 Posts 3 Posters 2.5k Views
  • P
    P
    perky
    Can the rear shock spring be taken off the shock on a 2006 125 X to paint it?
    • P perky
      @perky Yes
      You just need a spring compressor tool and then you can remove the shim plate that fastens it to the shock. Simple job to do.
      P 1 Reply Last reply
        @perky Yes
        P
        P
        perky
        @calum Hi mate what type of spring clamps did you use? Do you have a pic please?
        Regrads
        • P perky
          Regrads
          @perky alt text
          https://www.ebay.co.uk/itm/293381292840?hash=item444ee34328:g:7e4AAOSwgiVd-M2K
          P 2 Replies Last reply
            @perky alt text
            P
            P
            perky
            @calum ๐Ÿ‘ ๐Ÿ‘
              @perky alt text
              P
              P
              perky
              @calum Hi mate I bought these clamps but couldn't get the split collor off the shock to take spring off?
              • P perky
                @perky Yeah? Well it definitely comes off hence photo ^^^
                  There may be a big steel washer on the centre rod. It looks like itโ€™s fixed but can be forced down. You might need to do it to remove the collar. Sometimes it appears the split in the collar is to narrow
                    P
                    P
                    perky
                    @spookdog Yes mine has that but is a bit corroded and tight
                    S 2 Replies Last reply
                    • P perky
                      @perky
                      Wd40 and a big screwdriver on each side. It will move. The centre is stainless I think, so it wonโ€™t bond...
                      • P perky
                        @perky
                        The washer in question (finger pointed at) with spring washer under.
                        You can see that moving the washer up letโ€™s you access the thinner stainless steel inner Stantion which the collar will pass over ๐Ÿ˜œ ...
