  4. Engine rattleing after complete Rebuild
26 Posts 7 Posters 5.1k Views
  • Z Offline
    Z Offline
    zx125
    Hello,
    I have just rebuild my entire engine. All bearings and seals were replaced, the cylinder got honed to +0.25, got a new Meteor piston and the crankshaft got a new rod and got straightend. The Engine seams to have no leaks at all and starts up great. The only problem is a pretty annoying ratteling sound when the engine is decelerating. The clutch does not affect this sound also it appears when i m in gear and the clutch is pulled. Its exactly the same sound as in this Video:
    https://www.youtube.com/watch?v=pbfH93HpAto
    Do you have any Ideas what could cause this noise?
    declanD S 2 Replies Last reply
    • Z zx125
      Hello,
      @zx125 was your powervalve machined too? The rings might be catching pull the valve out and inspect also check the valve bushings for excessive wear, sure your piston is sized right it could be piston slap
      Z 2 Replies Last reply
        Z Offline
        Z Offline
        zx125
        wrote on last edited by zx125
        @declan thanks for that fast reply. The shop that honed the cylinder said that its not necessary to maschine the powervalve because it should fit with 56.25 still and there wasnt any visible overhang into the cylinder. also they sent me the piston with the correct size as far as i know but i´ll have to check that again i guess.
          Z Offline
          Z Offline
          zx125
          I just checked the Powervalve and it has some axial play but i cant feel any radial play. The Piston and Powervalve have no marks at all. It is my first 2 stroke Engine and I dont realy know if this axial play could cause the noise. Does anyone else have axial play in their powervalve and experiences rattleing?
          D MadGyverM 2 Replies Last reply
          • Z zx125
            Hello,
            @zx125
            That sounds like the kickstart cog isn’t disconnecting to me. The clicking sound you get if you push down the kickstart while the engine is running?
            Z 1 Reply Last reply
            • Z zx125
              DTR+NSR
              @zx125 put your finger on the exposed pulley end of the powervalve. With the engine running, you will know straight away if it's the powervalve rattling.
                @zx125
                Z Offline
                Z Offline
                zx125
                @spookdog My Engine sadly only has an E-Starter.
                @DTR+NSR I´ll try that as soon as my new battery is there.
                • Z zx125
                  @zx125
                  Same as but with the electric start motor. Make sure that it’s disengaging. Take it off and bump start it. At least try to check it off the list...
                    @zx125
                    Since it's an e start bike check the flywheel isn't rubbing on the stator I had only 2 bolts in and that caused major issues I was tearing the engine apart checking everything it was as simple as bolting the cover down evenly
                    • Z zx125
                      MadGyverM Offline
                      MadGyverM Offline
                      MadGyver
                      @zx125 Have you check the head gasket if it has marks,how much squish gap for possible piston slap,are the dowel pins in place?
                      • MadGyverM MadGyver
                        Z Offline
                        Z Offline
                        zx125
                        @madgyver haven´t checked the headgasket yet cause i didnt want to take it apart if i dont have to and hadn´t had time to check if the PW Play is the reason for that sound. If that sound does not come from the powervalve play i´ll have to take it apart. I took a 0.8 mm cylinderfoot gasket I think, and the head was straight, it wasnt planed, so there should be enough squish gap but please correct me if i took the wrong gasket or did something wrong here. I think there should be enough space but i´ll check all solution approaches this weekend and I´m so grateful that ya´ll have so many Ideas what could be wrong. I will give an Update this weekend. All dowelpins are in place and all bolts were torqued to spec.
                        • NottsbikerN Offline
                          NottsbikerN Offline
                          I had a DT125R engine that developed a random rattle once, turned out that the flywheel had come slightly loose and was moving on the crank.
                          • Z zx125
                            @zx125
                            Every cog in the engine is meshed together permanently, except the starter cog which is designed to engage when the starter is depressed and to slip if the kick start is kept down with the engine running, or the starter stays engaged. I don’t know about dtre starters, but car ones push forward as they are energised and rotate in much the same way...
                            The only other thing I can think of is that some different pistons use different small end bearings. If these can be mixed up I don’t know, but only one of the above makes any sense to me if it’s only making the noise on the over ~run...
                              @zx125
                              @spookdog
                              I forgot to ask! Does it make the noise on tickover as well?...
                                @spookdog
                                Z Offline
                                Z Offline
                                zx125
                                @spookdog So I had the Flywheel cover off today and and the starter overrunning clutch seems to be ok. Also there is no play in the mainbearings and there are no oil leaks at all. I think I´ll take of the cylinder tomorrow and check the small end bearing. the noise only appears when the enginge is decelerating and not on tickover.
                                NottsbikerN S 2 Replies Last reply
                                • Z zx125
                                  NottsbikerN Offline
                                  NottsbikerN Offline
                                  @zx125 not a loose exhaust is it making noise on the overrun?
                                  • Z zx125
                                    @zx125 said in Engine rattleing after complete Rebuild:
                                    @spookdog I think I´ll take of the cylinder tomorrow and check the small end bearing
                                    I think that’s your only option 👍
                                    The only time I ever had a noise like that it was because my barrel & piston were badly worn. You could get a lolly stick between the two! My piston was slapping around on the overrun. I don’t think it’s that because of the rebuild. It’s just the only other thing I can think of ...
                                    • Z Offline
                                      Z Offline
                                      zx125
                                      Hello,
                                      First of all I want to thank everybody for your constructive answers.
                                      sadly i hadn´t had time for my project bike this summer. After I checked the piston size it was clear that the loud ratling was piston slap because the clearance between bore and piston was around 0,09-0,1 mm instead of 0,05 mm. So I got a new piston that fits the bore of my cylinder, installed it and the bike ran way smoother. But after around 200-300 km I realized a new sound coming from the left side of the Engine. I uploaded a video: https://www.youtube.com/watch?v=Qj7QRH6IZOc
                                      I hope somebody has an Idea what this ringing sound could be. sounds like a bad bearing to me but all bearings were replaced like 350 km ago and when changing the piston the big end bearing and the main crankbearings had no radial play at all. I think the sound is coming from the left side of the Engine. Also I´d like to note that the clutchbasket has some play but the sounds doesn´t seem to come from the right side of the bike. except this noise the engine runs great and it seems to have good power as far as i can tell because i have not been reving higher than 6500 rpm.
                                      • Z zx125
                                        Hello,
                                        @zx125
                                        @zx125
                                        I’m glad you got the piston right. As to a noise? I’m just not hearing anything nasty. Either I’m missing it or you’re being paranoid...
                                          @zx125
                                          @zx125
                                          Z Offline
                                          Z Offline
                                          zx125
                                          @spookdog That´s not impossible since its my first two stroke bike and I normally drive a 600 ccm 4 cylinder which runs way smoother. I don´t realy know how to describe the sound but I think ringing wasn´t the best word to describe the sound. It is most audible to me from around 0:08-0:15 when the engine is decelerating and to me it seems to have the crank RPM if it is a rotating part so probably nothing gearbox related. But it´s good to hear that the engine sounds normal.
