  3. Carburetor
  4. Where’s Wally / The idle jet
16 Posts 6 Posters 3.3k Views
  • Stevie WonderS Offline
    Stevie Wonder
    So someone’s gonna laugh but wheres the idle jet?
    I know where the main and pilot is and know you’ve also got your power and pick up’s but where’s the bloody idle???😂
    Finally got over my fear of working on carbs though, fucking things 😂
    markus.wM K 2 Replies Last reply
      markus.wM Offline
      markus.wM Offline
      @stevie-wonder idle jet is another name for pilot jet.
      • markus.wM markus.w
        Stevie Wonder
        @markus-w cheers Markus
          @stevie-wonder
          If you have compressed air it makes them easier to work on. Just make sure the jets are clear and blow through any holes in the carb so they’re clear too...
            @stevie-wonder
            Stevie Wonder
            @spookdog said in Where’s Wally / The idle jet:
            @stevie-wonder
            Unfortunately I don’t have compressor, so no air line’s here.
            Believe it or not you can actually buy cans of compressed air, I’ve been meaning to buy a couple cans for that exact purpose. I just feel like a bit of a twat paying money for something I can breathe for free, you know what I mean?
            https://www.ebay.co.uk/itm/2-x-400ml-Compressed-Air-Duster-Gas-Spray-Cleaner-HQ-MAX-POWER-HFC-Free-Can-/283888471903?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
            I also came up short for having the right flathead screwdriver, my precious ones weren’t wide enough and every other one had was to large in diameter to even go down the hole, luckily I bought this cheap little eBay gadget that came up trumps. I’m not sure if you or anyone has one but I highly recommend it, only a fiver too.
            https://www.ebay.co.uk/itm/Carburetor-Carb-Jet-Cleaning-Tool-Set-Wire-Brush-Cleaner-Kit-For-Motorcycle-ATV-/383531854604?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
            This little gadget really saved the day and allowed to clear out any gunk and shit that was blocking that pilot jet up.
            I forgot how tiny the holes are. I also reinstalled a “1KT” carb net filter, I took mine off the bike a couple years ago and lost it. In hindsight what a total idiot. No wonder I’ve had to have my carb cleaned so regularly.
              @stevie-wonder
              @stevie-wonder Get yourself one of these:
              https://www.amazon.co.uk/Wurth-Pump-Bottle-Brake-Cleaner/dp/B07D4FSXX8/ref=asc_df_B07D4FSXX8/?tag=googshopuk-21&linkCode=df0&hvadid=310493449173&hvpos=&hvnetw=g&hvrand=11081789735738343749&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006741&hvtargid=pla-697024686122&psc=1
              S declanD Stevie WonderS 3 Replies Last reply
                @calum
                I use them as well, good stuff...
                  @calum yeah they're definitely wurth the money😅
                    K Offline
                    K Offline
                    kevin
                    @stevie-wonder dtpedia.de has all the info you need on the carb, its a German site, google translates obviously.
                      Stevie Wonder
                      @declan said in Where’s Wally / The idle jet:
                      Ffs dec 😂🙄
                        Stevie Wonder
                        @calum said in Where’s Wally / The idle jet:
                        Reminds me of being a kid again, my dad used to use these when he was a window cleaner.
                        That’s a smart idea Callum, appreciate it.
                        I’d never Chuck any brake cleaner in it either, quite happy with a can
                          @stevie-wonder it's the same stuff as Carb Cleaner.
                            Stevie Wonder
                            So after cleaning my carb my bike still only starts with choke, proceeds to then idle really high (id guess about 3.5/4k), then stays at the same rpm after choke is taken off, if left for a couple minutes you can flick the choke on again and it’ll go to cut out as you’d expect.
                            Idle screw is unresponsive, doesn’t matter if it’s all the way in or out
                            Gonna spray some WD all around the air boot and inlet and see if there’s any leaks and see if I’m not being patient enough waiting for the bike to adjust to the idle setting
                              @stevie-wonder
                              Did this start recently by itself? Or have you had the carb off then it happened?
                              Either way it sounds like a big airleak. Check the rubber inlet for cracks inside and out...
                              I just cured a mild tickover problem by fitting a new slide body gasket (slide top as well) Yours sounds massive though.
                                Stevie Wonder
                                @spookdog yeah it happened on its own and not after any aggressive riding either.
                                It occurred around a month ago, I’d only been using my bike to get to work.
                                I’m not 100% sure but I remember one morning on my way to work my bike nearly cutting out on me and me having the crawl the last 1/4 the journey to work keeping it in high gear and low revs otherwise if you put it under to much load it would cut out.
                                If memory serves me right after that it was fine. It’d Rev out no problem and go through powerband fine but was
                                either idling really high and wouldn’t settle to down to normal idle speed or would die from lack of revs whilst under load.
                                  @stevie-wonder
                                  I would check for massive air leaks around the carb & inlet, also maybe the magneto side oil seal. Especially if the revs are really ring-ting, ting, ting, ting fuel starved sounding...
