Power valve
Im having trouble fitting a power valve. Im confused because on the engine it says num 1- num 2 cables then on the unit it says 2-1 so from what I've looked at in other units(youtube) cable 1 goes to numb 2 and cable 2 goes to numb 1 on the power unit but i am having real trouble getting the cables on and when i do i can’t seem to line the power valve ( engine side) up to the hole to set it. Or am i putting cables on totally wrong ?. Can anyone help ?
@andyjack yes that's correct, 1 goes to 2 and 2 to 1. They don't cross. Obviously use the adjusters to slacken the cable first.
C Calum referenced this topic on
