  4. Missing some wires for the cdi
16 Posts 4 Posters 4.3k Views
  • D Offline
    dan28
    The engine an loom are 1989 the cdi is I believe 3nc the writing has worn off
    To make it easier I ll list all the wires that the cdi has in case I got the code wrong
    Right side of cdi
    Male 2 pin plug
    white/ red . Wire
    Black . Wire
    Female 2 pin plug
    Green/ white Wire
    Black an red wire
    These plugs go to stator
    Left side of cdi
    2 pin plug
    Dark blue wire
    Light blue wire
    This is for neutral an oil light
    Twin Black wire from cdi goes to earth
    Black / white from cdi goes to black / white in loom not sure what it's for ?
    Orange wire from cdi goes to coil ?
    Blue / yellow from cdi should go to Black/ yellow I can't find it in the loom ?
    Black / yellow from cdi should go to.red an white possibly power valve?
    S HOTSHOT IIIH 3 Replies Last reply
    • D dan28
      Right side of cdi
      Male 2 pin plug
      white/ red . Wire
      Black . Wire
      Female 2 pin plug
      Green/ white Wire
      Black an red wire
      Left side of cdi
      2 pin plug
      Dark blue wire
      Light blue wire
      @dan28
      Does your bike run? If so what’s the problem?
      Do you have a power valve servo fitted? The early 1988~1996 bikes have a servo with 3 wires (not 5) a single black with white (or yellow!) stripe wire and a twin connector with a black wire and a brown wire...
      I have some spare wires in a box, how many do you need? 😜
      D 1 Reply Last reply
        @dan28
        dan28
        @SpookDog said in Missing some wires for the cdi:
        @dan28
        The dtr engine is in a different bike
        I ve not tried to start it yet
        The loom had to be chopped an lengthend
        I ve wrote down that cdi black an yellow goes to red an white
        An that blue an yellow from.cdi goes to black an yellow in the loom but that was ages ago an now I can't find either wire in the loom side
        • D dan28
          Right side of cdi
          Male 2 pin plug
          white/ red . Wire
          Black . Wire
          Female 2 pin plug
          Green/ white Wire
          Black an red wire
          Left side of cdi
          2 pin plug
          Dark blue wire
          Light blue wire
          @dan28 said in Missing some wires for the cdi:
          Right side of cdi
          Male 2 pin plug
          white/ red . Wire
          Black . Wire
          Female 2 pin plug
          Green/ white Wire
          Black an red wire
          Correct
          Left side of cdi
          2 pin plug
          Dark blue wire
          Light blue wire
          Correct
          Correct
          This is for the kill button on the handlebars
          Correct
          Blue/yellow from CDI should go to blue/yellow on the loom, a single bullet connector. This goes to the sidestand switch
          Black/yellow from CDI is the YPVS signal wire, goes to black/yellow on the 3-wire YPVS servo. The only red/white wire on the 3NC loom is the short section of the battery +ve lead containing the fuse holder
          Did I just respond to this on one of the DTR Facebook pages? I posted up a pic of the 3NC loom, will try and upload it onto here
          • D dan28
            Right side of cdi
            Male 2 pin plug
            white/ red . Wire
            Black . Wire
            Female 2 pin plug
            Green/ white Wire
            Black an red wire
            Left side of cdi
            2 pin plug
            Dark blue wire
            Light blue wire
            @dan28 3NC wiring diagram below
            S CalumC 2 Replies Last reply
            • HOTSHOT IIIH HOTSHOT III
              Please stop posting full on quote mode peeps! It’s making me dizzy trying to read posts!!...
                @HOTSHOT-III You can embed images bud:
                Just got to use the right link: https://live.staticflickr.com/65535/52172141696_84e3b69382_b.jpg
                HOTSHOT IIIH 2 Replies Last reply
                • D Offline
                  dan28
                  thanks hot shot
                  yes that was me on fb
                  so blue an yellow is for sidestand
                  i have a black with yellow stripe single bullet connector thats labelled as goes to red an white i think this is meant to go to the servo
                  i m not sure what code my cdi is dont think its 3nc
                  • D dan28
                    thanks hot shot
                    @dan28
                    Black with yellow stripe goes to 3wire servo. Along with back wire & brown wire double block connector from the loom...
                    • D dan28
                      thanks hot shot
                      @dan28 Yes that's correct, brown is main feed from the ignition switch on Yamahas and obviously black is earth. Interestingly if you apply battery voltage to the black and brown wires of a serviceable 3-wire servo it will perform its cleaning cycle even when removed from the bike as the control circuit is inside the servo itself and the black/yellow signal wire from the CDI just tells the servo the engine speed.
                      Only other CDI unit I can think of could be a 3BN from the very first 1988 DTR; I think the wiring is very similar to a 3NC but you'd probably have a 26mm round slide carb if that's the case.
                        @Calum Thank you! How do you obtain a staticflickr link from the image please? Had a nose around last night and couldn't find it, maybe because I'm using the free version of Flickr?
                          @HOTSHOT-III Uhh, you edited your post with the URL in it.
                          I don't use flicr personally, but Right Click + Copy Image Location ought to give you the URL.
                            @Calum OK cool, thought I'd still done something wrong as the actual image still didn't appear like in your comment above. Still the OP can access the wiring diagram so all good πŸ‘
                              @HOTSHOT-III Take the URL and put it in side the () of a []().
                              The syntax is Markdown
                                @Calum Finally sorted as you can see above!!
                                Turns out on my computer you have to click the download link on a Flickr photo, choose the size you want, THEN copy and paste the URL. Might be because I'm still using the Victorian technology that is Windows 7?
                                Anyway thanks for your patience πŸ‘ πŸ‘Ό
                                  @HOTSHOT-III Yeah, I only use Linux and Firefox.
