  3. Brakes
  4. Would anyone be willing to help me
7 Posts 4 Posters 4.0k Views
  • V
    V
    vtrn_raptor
    Hello I was wondering if anyone on here would be willing to make be a bracket for the front brake on my dt supermoto conversion I'm willing to pay I'm going to be using the standard dtr brake caliper as I can't find any dtx ones
    • MightymanM
      MightymanM
      Really would recommend to keep looking for one as I'm sure the DTX caliper will be noticeably better.
      • V vtrn_raptor
        @vtrn_raptor I spotted this caliper which would most likely need some modifying, as I doubt if the bracket would be a direct fit? But as the seller has put enormous amounts of detail in his listing, it's hard to say which bike it's actually from? However, it looks very similar to the DTX one and I'm sure Brembo probably made a ton of generic calipers, which the manufacturers used for their bikes. So their probably universal so-to-speak? And as you're going to use a custom bracket, it could be easily made to fit, so long as its in full working order? I do not know if the master cylinders are different on the DT and DTX, but for £25 it could be well worth it???
        http://www.ebay.co.uk/itm/Ktm-Front-Brake-Caliper-/262523023923?hash=item3d1f977233:g:JmoAAOSwanRXhpWj
        • V
          V
          vtrn_raptor
          I would but I want to be able to switch wheels from supermoto to off-road and the engineering place charge over £100
          D NINJAN 2 Replies Last reply
          • V vtrn_raptor
            dan28
            @vtrn_raptor said in Would anyone be willing to help me:
            Over £100 !
            Do you need wheel spacers too
            It's easy enough to make your self
            Try this
            Take a piece if clear Perspex sit it on your caliper an use a soldering iron to make mark where the holes are
            Cut it to shape with dremmel an then bolt to your caliper sit it on your fork poke the soldering iron through the holes on the fork
            Once you get it all lined up make it out of thicker plastic or wood before making it out of metal
            • D
              dan28
              I have an adaptor for dt x caliper an Dt fork
              It's been cut but I could liquid metal it back together an you can use it for a template
              I also have a dtx caliper but I need it can add photos of it to help u find one on eBay
              • V vtrn_raptor
                @vtrn_raptor I spotted these SM wheels for sale and noticed the advert also had a picture of the spec for an adapter bracket, using the stock DT caliper. Which I though this might be useful too you???
                Full ad here;
                https://www.gumtree.com/p/replacement-parts/dt-125-excel-supermoto-wheels/1180869633
