is a standard dt tail pipe restricted
As title really doe anyone know if the DT tail pipe restrictive, if so can they be unrestricted as I would like to keep the standard pipe,thanks peeps
@scotty As far as I know it isn't, you might climb a couple horsepower by getting a DEP system but I've found no problem sticking with stock.
@Minia cheers mate,I've got a big one expansion chamber but I want to keep the original look hence using the standard pipe
@scotty I've just changed my exhaust on my dtr to a dep back pipe as I was told the standard pipes have washers welded into them
@smudge1995 said in is a standard dt tail pipe restricted:
Did you notice any difference ? Smudge
@scotty not a huge amount but it don't sound like it's all choked up now the sound is so much crisper... to me it sounded blocked with the restricted one
@scotty I would be surprised if there was not some sort of restriction in the stock pipe. Some wadding at the very least? Hence why performance pipes work as they remove any restriction to the air flow. Plus normally aspirated engine's require some back pressure too keep the system balanced. The front pipe definitely has some wadding and restriction in there, so it would make sense that the tail pipe had some as well.
As a general rule: 2 strokes are restricked in the header/downpipe, and 4 strokes in the silencer/tail pipe.
