Dt125r 2003 electrical fault
I just bought my first dtr125 2003 model. My side light and speedo light turns on when i press my brakes after fitting all new bulbs and a new battery. Any ideas what could be the fault? Cheers.
Most likely a wiring fault, have a look behind the headlight cowl and make sure everything's in the right place.
as you've just brought it i assume you dont know the history of the bike ? anyone could have messed with it
have you got a Haynes manual?
is this a bright orange supermoto by any chance ?
Its a bad earth connection
