  3. Framework
  4. Upgrading cooler/radiator
8 Posts 6 Posters 2.9k Views
  • J Offline
    J Offline
    Jens Eskildsen
    So, I've seen a few guys toss the oiltank, and mount dual coolers..
    But have anyone found a single good aluminium rad to replace the original one? It seems like theres room for a slightly bigger once, with more depth for added cooling.
    Perhaps a cooler from a different model could fit, or a universal one?
    I ride mine in the gnarly stuff, and as outside temperatures rise, so does the watertemperature. I've fitted a fan with on on/off switch just to toy with the idea, but a better rad would for sure be way better.
    • britshgigoloB Offline
      britshgigolo
      there is a post in the build thread where someone has fabricated a bigger ally rad to fit the dt
      • Louis-DT-WRL Offline
        Louis-DT-WR
        That me, see my thread. Just finished it today. alt text
        D 1 Reply Last reply
        3
        • J Offline
          J Offline
          Jens Eskildsen
          Yeah, I saw that. Impressive work, but way above my skill-level...
          I was hoping something would fit with monor tweaks, and no welding.
          • J Jens Eskildsen
            Louis-DT-WR
            @Jens-Eskildsen well you could just fit hoses and adapters
            • Louis-DT-WRL Louis-DT-WR
              dan28
              @louis-dt-wr what bike is that radiator intended for
              MadGyverM 1 Reply Last reply
                @dan28 I use DT230 Lanza radiators. Brackets are a direct replacement and there are Aluminium aftermarket ones.
                • D dan28
                  MadGyverM Online
                  MadGyverM Online
                  MadGyver
                  @dan28 You can use the right radiator from a DT200R (3ET) it uses the same bracket the DT125R has for the oil bottle.
