Speedo drive gear help needed
The worm gear was seized now moving I can make the drive work by rotating the cable but not by the the tab that's suppposed to drive it any ideas @Calum
The 3 tabs can be bent inwards, then it wont engage.
Remove the circlip/lockring, take the washer with the tabs out, and bend them back so they're straight.
@jens-eskildsen they look straight to me but I will see any way
@jens-eskildsen the thing with the tabs was not installed right it was not seated I've put it back on and it works! Seems a bit jittery watching the needle but it reads the speed not ride it yet though
I had this problem the tabs were worn on the wheel, i started cheapest option first being the cable and lastly changed the wheel which sorted it
@andrewj1680 hopefully mine is okay now but if it starts again I need to add another washer in there to keep it seated
