  4. Help needed
Help needed
12 Posts 7 Posters 2.4k Views 1 Watching
  • V vtrn_raptor
    Can anyone tell me what size this screw is as mine snapped and had to drill it out and now I need to get a heli coil to fix it part number is 9851706012
    @vtrn_raptor Post a pic is the easiest way of pinpointing it's location and size etc. dude.
      @vtrn_raptor said in Help needed:
      9851706012
      If the photo is anything to go buy, 20mm M6.
      But that's if the photo is anything to go by...
      • V
        V
        vtrn_raptor
        Yeah it's a m6 just ordered the tools and the heli coils now should hopefully have the bike back on the road by Thursday fingers crossed
        • V vtrn_raptor
          @vtrn_raptor Helicoil should be absolutely last resort.
          In most cases, the screw can be removed. I would recommend only helicoiling when all else fails...
          DartyD 1 Reply Last reply
            @calum Yeah... Not when you don't have the right size thread anymore because you've had to drill it out.
            It's your only resort.
              @darty You can drill just the bolt. If you've cross threaded the insert, in can be cleaned up again with a die.
              • ZrakoZ
                ZrakoZ
                Zrako
                The screws he looking for are for the small cover plate for right crankshaft seal. I think its m5 so if you damaged the thread you can drill it to suit same type of screw size m6. And buy and anti seize molybdenum paste. Im used it on every bolt on the engine.
                1979 Jawa Mustang 50
                2003 Gilera DNA 125 R.I.P
                2015 Keeway TX 125 SM
                2006 Yamaha DT 125 X
                • ZrakoZ Zrako
                  @zrako Ahh, loctite on engine internals, no way do I want that coming lose. Besides, it's soaked in oil so shouldn't become seized.
                  As said, impact driver goes a long way here.
                    scrimsmustang
                    Never a truer word said !
                    • V
                      V
                      vtrn_raptor
                      Theirs no threads left so I've not got a choice but to do it unfortunately but on the plus side atleast it's do able and not hard to do
