  3. Wheels
  4. Dtx rim in DTR/DTRE fork
7 Posts 4 Posters 2.1k Views
  • B
    B
    Bananper
    Does anyone know what needs to be done to make it fit? I've seen a couple who has done it but haven't found an answer.
      Pretty sure it's the spacers from a DTX rim, and then a bracket for the caliper, since the DTX uses a bigger caliper/disc.
      B 1 Reply Last reply
        B
        B
        Bananper
        @calum Thanks for the answer 😄
        Do you know what a bracket like that looks like?
        • B Bananper
          @bananper You'll have to make it, the DTX fork just extends the arms longer.
          • Glynn123G
            Glynn123G
            Glynn123
            DTX wheel hubs are slightly different, the disc side wheel spacer is different so you'll need that, then it should fit on with speedo drive. You'll need to make a caliper bracket though and I'd imagine you'd find the standard DTR forks abit soft.
            • B Bananper
              @bananper See this thread dude;
              https://dt125r.co.uk/topic/207/how-to-supermoto-a-dt-using-donor-parts-from-other-yammy-s
              Maybe that will shed some light on which parts are compatible???
              • B
                B
                Bananper
