  3. Wheels
  4. Dtx rim in DTR/DTRE fork
7 Posts 4 Posters 2.0k Views
  • B Offline
    B Offline
    Bananper
    Does anyone know what needs to be done to make it fit? I've seen a couple who has done it but haven't found an answer.
    N 1 Reply Last reply
      Pretty sure it's the spacers from a DTX rim, and then a bracket for the caliper, since the DTX uses a bigger caliper/disc.
      B 1 Reply Last reply
        B Offline
        B Offline
        Bananper
        @calum Thanks for the answer 😄
        Do you know what a bracket like that looks like?
        • B Bananper
          @bananper You'll have to make it, the DTX fork just extends the arms longer.
          • Glynn123G Offline
            Glynn123G Offline
            Glynn123
            DTX wheel hubs are slightly different, the disc side wheel spacer is different so you'll need that, then it should fit on with speedo drive. You'll need to make a caliper bracket though and I'd imagine you'd find the standard DTR forks abit soft.
            • B Bananper
              @bananper See this thread dude;
              https://dt125r.co.uk/topic/207/how-to-supermoto-a-dt-using-donor-parts-from-other-yammy-s
              Maybe that will shed some light on which parts are compatible???
              • B Offline
                B Offline
                Bananper
                This post is deleted!
