  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 60.6k Views
    @irongamer727 Just need to get yourself a kickstart now and it'll be like a real crosser.
    Irongamer727I Offline
    @calum I've thought about it. Could get an old dtr engine for £90 with kickstart.
      @irongamer727 Yeah, that's about the going rate for everything you need, plus you'd have a spare engine lol.
      • Irongamer727I Offline
        What do you think? The DT is refusing to start cold. Always have to bumpstart it. Choke or not. Once warm everything is more than good.
          @irongamer727 You running the stoke carb?
          I always had issues with the stock carb.
          What plug you running.
            @calum br9eix 90km from brand new. Will try to fiddle with the air screw.
              @irongamer727 Before you mess with the settings, try stifling the airbox, restrict the air box, see if that makes it better or worse. Or take the snorkel out. That'll give you a hint as to what the problem is.
                @calum the entire snorkel and the top plastic is cut out. I'll comment on the post I did a while back and you'll see
                  Ah yeah, so with that then, it probably just wants a tad more fuel to compensate.
                    @calum I guess I could order a bigger idle jet or wait for the summer...
                      @irongamer727 Either way it doesn't sound right.
                      If it were fueling, it would start if you opened the throttle ajar.
                        #56
                        @calum recommendations then?
                        It has never ever wanted to start with throttle. With or without the big bore. With the previous cylinder it would at least start fast cold.
                          @irongamer727 Better carb mate.
                          I had issues with my Athena as well. Carb sorted that out.
                          I had issues with the stock cylinder. Carb sorted that out.
                            @calum ehm. No. Won't change that. Problem lies somewhere else.
                              If I only had a kickstart...
                                @irongamer727 That's what you want mate.
                                https://www.ebay.co.uk/itm/YAMAHA-TZR-125-4DL-yr-92-CARBURETTOR-DELLORTO-VHSA-32-GS/282744266127?hash=item41d4df1d8f:g:GTwAAOSwrhhaFTOk
                                That'll fix your problem guaranteed!
                                I literally don't know why the original carb sucks balls lol.
                                  @calum I’d rathet bump start it than pay that price lol
                                    @declan Yeah but that's just the cost of tuning for you bud.
                                      @calum cost of genuine carbs tbh carbs are quite pricey
                                        Things are not going my way. 180km into break in I spotted 2 small holes on the cylinder. I have spoken to the company I bought the kit from and they will contact Athena for assistance. Hopefully this ends well..
                                        https://youtu.be/JSdh4gz1p8w
                                          What do you think? I've now fitted a 310 main jet and she's still a bit down on power. It felt better than the 290 for sure. Now I'm thinking about buying a couple of extra jets, 320-350.
                                          Is this even possible? I've not spoken to anyone running higher than 280.
