  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 63.4k Views
    Ah yeah, so with that then, it probably just wants a tad more fuel to compensate.
      @calum I guess I could order a bigger idle jet or wait for the summer...
        @irongamer727 Either way it doesn't sound right.
        If it were fueling, it would start if you opened the throttle ajar.
          #56
          @calum recommendations then?
          It has never ever wanted to start with throttle. With or without the big bore. With the previous cylinder it would at least start fast cold.
            @irongamer727 Better carb mate.
            I had issues with my Athena as well. Carb sorted that out.
            I had issues with the stock cylinder. Carb sorted that out.
              @calum ehm. No. Won't change that. Problem lies somewhere else.
              • Irongamer727I
                If I only had a kickstart...
                  @irongamer727 That's what you want mate.
                  https://www.ebay.co.uk/itm/YAMAHA-TZR-125-4DL-yr-92-CARBURETTOR-DELLORTO-VHSA-32-GS/282744266127?hash=item41d4df1d8f:g:GTwAAOSwrhhaFTOk
                  That'll fix your problem guaranteed!
                  I literally don't know why the original carb sucks balls lol.
                    @calum I’d rathet bump start it than pay that price lol
                      @declan Yeah but that's just the cost of tuning for you bud.
                        @calum cost of genuine carbs tbh carbs are quite pricey
                        • Irongamer727I
                          Things are not going my way. 180km into break in I spotted 2 small holes on the cylinder. I have spoken to the company I bought the kit from and they will contact Athena for assistance. Hopefully this ends well..
                          https://youtu.be/JSdh4gz1p8w
                          • Irongamer727I
                            What do you think? I've now fitted a 310 main jet and she's still a bit down on power. It felt better than the 290 for sure. Now I'm thinking about buying a couple of extra jets, 320-350.
                            Is this even possible? I've not spoken to anyone running higher than 280.
                            • 2
                              2stroketerry
                              If using a TM28 carb then need a 300 main jet with a 27.5 idle jet. Main jets go up to 430. Put clip in the bottom groove on needle.
                              https://www.sip-scootershop.com/en/products/main+jet+mikuni+300+_40703000
                              https://www.sip-scootershop.com/en/products/idle+jet+mikuni+275+_40726000
                              • 2 2stroketerry
                                @2stroketerry I'm running 310 now and it's certainly not optimal. Idle is 35 now, definitely too big.
                                • Irongamer727I
                                  In reality, what would cause the bike not to start on the first or second spin on the starter. Is it just down to the pilot jet and fuel/Air mix?
                                  Obviously a good battery and fresh electric components will make things easier but I got that covered.
                                  I've read in the Haynes that there is supposed to be a starter jet in the later carbs? Much of what that books says makes no sense...
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    I run the autolube on my dt125r bottom end with wr200 top end. I just adjusted it to suit the larger capacity. I've run it for years. Autolube is brilliant
                                    • Louis-DT-WRL Louis-DT-WR
                                      #70
                                      @louis-james hows that thing to start?
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        First kick 99% of the time
                                          @louis-james you run the 28mm carb? The flat one?
