  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 63.4k Views
    @calum recommendations then?
    It has never ever wanted to start with throttle. With or without the big bore. With the previous cylinder it would at least start fast cold.
    @irongamer727 Better carb mate.
    I had issues with my Athena as well. Carb sorted that out.
    I had issues with the stock cylinder. Carb sorted that out.
      @calum ehm. No. Won't change that. Problem lies somewhere else.
      • Irongamer727I
        If I only had a kickstart...
          @irongamer727 That's what you want mate.
          https://www.ebay.co.uk/itm/YAMAHA-TZR-125-4DL-yr-92-CARBURETTOR-DELLORTO-VHSA-32-GS/282744266127?hash=item41d4df1d8f:g:GTwAAOSwrhhaFTOk
          That'll fix your problem guaranteed!
          I literally don't know why the original carb sucks balls lol.
            @calum I’d rathet bump start it than pay that price lol
              @declan Yeah but that's just the cost of tuning for you bud.
                @calum cost of genuine carbs tbh carbs are quite pricey
                • Irongamer727I
                  Things are not going my way. 180km into break in I spotted 2 small holes on the cylinder. I have spoken to the company I bought the kit from and they will contact Athena for assistance. Hopefully this ends well..
                  https://youtu.be/JSdh4gz1p8w
                  • Irongamer727I
                    What do you think? I've now fitted a 310 main jet and she's still a bit down on power. It felt better than the 290 for sure. Now I'm thinking about buying a couple of extra jets, 320-350.
                    Is this even possible? I've not spoken to anyone running higher than 280.
                    • 2
                      2stroketerry
                      If using a TM28 carb then need a 300 main jet with a 27.5 idle jet. Main jets go up to 430. Put clip in the bottom groove on needle.
                      https://www.sip-scootershop.com/en/products/main+jet+mikuni+300+_40703000
                      https://www.sip-scootershop.com/en/products/idle+jet+mikuni+275+_40726000
                      • 2 2stroketerry
                        @2stroketerry I'm running 310 now and it's certainly not optimal. Idle is 35 now, definitely too big.
                        • Irongamer727I
                          In reality, what would cause the bike not to start on the first or second spin on the starter. Is it just down to the pilot jet and fuel/Air mix?
                          Obviously a good battery and fresh electric components will make things easier but I got that covered.
                          I've read in the Haynes that there is supposed to be a starter jet in the later carbs? Much of what that books says makes no sense...
                          • Louis-DT-WRL
                            Louis-DT-WRL
                            I run the autolube on my dt125r bottom end with wr200 top end. I just adjusted it to suit the larger capacity. I've run it for years. Autolube is brilliant
                            • Louis-DT-WRL Louis-DT-WR
                              #70
                              @louis-james hows that thing to start?
                              • Louis-DT-WRL
                                Louis-DT-WRL
                                First kick 99% of the time
                                  @louis-james you run the 28mm carb? The flat one?
                                  • Louis-DT-WRL
                                    Louis-DT-WRL
                                    I used to, I had the tmx30 for a while, now a tm34ss
                                      @louis-james you ran the 28 with the wr200?
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        No, I had the 30 when it was still a 125. Lid was cut off the air box the the 28mm btw
                                          @louis-james alright
