  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 63.4k Views
  • Irongamer727I
    Things are not going my way. 180km into break in I spotted 2 small holes on the cylinder. I have spoken to the company I bought the kit from and they will contact Athena for assistance. Hopefully this ends well..
    https://youtu.be/JSdh4gz1p8w
    • Irongamer727I
      What do you think? I've now fitted a 310 main jet and she's still a bit down on power. It felt better than the 290 for sure. Now I'm thinking about buying a couple of extra jets, 320-350.
      Is this even possible? I've not spoken to anyone running higher than 280.
      • 2
        2stroketerry
        If using a TM28 carb then need a 300 main jet with a 27.5 idle jet. Main jets go up to 430. Put clip in the bottom groove on needle.
        https://www.sip-scootershop.com/en/products/main+jet+mikuni+300+_40703000
        https://www.sip-scootershop.com/en/products/idle+jet+mikuni+275+_40726000
        • 2 2stroketerry
          @2stroketerry I'm running 310 now and it's certainly not optimal. Idle is 35 now, definitely too big.
          • Irongamer727I
            In reality, what would cause the bike not to start on the first or second spin on the starter. Is it just down to the pilot jet and fuel/Air mix?
            Obviously a good battery and fresh electric components will make things easier but I got that covered.
            I've read in the Haynes that there is supposed to be a starter jet in the later carbs? Much of what that books says makes no sense...
            • Louis-DT-WRL
              Louis-DT-WRL
              I run the autolube on my dt125r bottom end with wr200 top end. I just adjusted it to suit the larger capacity. I've run it for years. Autolube is brilliant
              • Louis-DT-WRL Louis-DT-WR
                #70
                @louis-james hows that thing to start?
                • Louis-DT-WRL
                  Louis-DT-WRL
                  First kick 99% of the time
                    @louis-james you run the 28mm carb? The flat one?
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      I used to, I had the tmx30 for a while, now a tm34ss
                        @louis-james you ran the 28 with the wr200?
                        • Louis-DT-WRL
                          Louis-DT-WRL
                          No, I had the 30 when it was still a 125. Lid was cut off the air box the the 28mm btw
                            @louis-james alright
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @irongamer727 recommend getting a decent reed block on there. Many can be modified to fit
                                @louis-james naah at the moment I simply want her to run good, start easy and stay that way.
                                • Irongamer727I
                                  #79
                                  As I suspected my pilot jet to be too big (size 35) I ordered a smaller 25. But the bike literally ran like shit and the idle was very uncontrolled and the bike just sounded wrong!
                                  Is the next step to order a larger?
                                  I can without a drop in rpm turn the airscrew all the way in, no change really.
                                  That must be an indicator that it's to small right?
                                    Yeb sounds like you need to up the idlejet in size.
                                    • Irongamer727I
                                      @Calum agree?
                                      • Glynn123G
                                        Glynn123G
                                        Glynn123
                                        Id go a fair bit bigger idle jet than a 25, im running a 27.5 pilot on 125 bore with snorkel removed here in sunny scotland, id imagine the 170 kit would require a fair bit bigger pilot especially in your climate, maybe a 30?
                                        • Glynn123G Glynn123
                                          @glynn123 I'm running 35 now.
