  3. Top End
  4. Athena 170
Athena 170
112 Posts 14 Posters 60.5k Views
  • Louis-DT-WRL Louis-DT-WR
    First kick 99% of the time
    Irongamer727I Offline
    @louis-james you run the 28mm carb? The flat one?
    • Louis-DT-WRL Offline
      I used to, I had the tmx30 for a while, now a tm34ss
        @louis-james you ran the 28 with the wr200?
          No, I had the 30 when it was still a 125. Lid was cut off the air box the the 28mm btw
            @louis-james alright
              @irongamer727 recommend getting a decent reed block on there. Many can be modified to fit
                @louis-james naah at the moment I simply want her to run good, start easy and stay that way.
                • Irongamer727I Offline
                  #79
                  As I suspected my pilot jet to be too big (size 35) I ordered a smaller 25. But the bike literally ran like shit and the idle was very uncontrolled and the bike just sounded wrong!
                  Is the next step to order a larger?
                  I can without a drop in rpm turn the airscrew all the way in, no change really.
                  That must be an indicator that it's to small right?
                    Yeb sounds like you need to up the idlejet in size.
                      @Calum agree?
                      • Glynn123G Offline
                        Glynn123G Offline
                        Glynn123
                        Id go a fair bit bigger idle jet than a 25, im running a 27.5 pilot on 125 bore with snorkel removed here in sunny scotland, id imagine the 170 kit would require a fair bit bigger pilot especially in your climate, maybe a 30?
                        • Glynn123G Glynn123
                          @glynn123 I'm running 35 now.
                            I'm now contacting Adrenalin (the company I bought the kit from) and I'm asking for a refund.
                            The issue is that the casting is shite, there is a microscopic hole on the cylinder that leaks coolant, and that the powervalve housing is too big so the bush cannot seal properly.
                            Exhaust gases and oil pours out if the pv, bruh.
                            I have more or less demanded a refund, but I don't think they will give me that until Athena in Italy have examined it..
                            In theory I won't have the Dt running for over a month, unless I immediately mount another cylinder I had from a spare engine..
                            That means all my jets have been bought in vain and all that, great.
                            The lesson here is: Do not buy the stupid Athena big bore kit. Even if you don't get a really bad one the power gains are barely notable.
                            To really benefit from it a lot more have to be done.
                            Sometimes life isn't easy..
                            CalumC D 2 Replies Last reply
                              @irongamer727 I'm sorry to hear that bud, been there, done that, got the T-Shirt.
                              To be fair, I didn't have half of the issues you have and at the time (being 17) I thought the gains were decent.
                              But having been on an Aprilia, and for you the Honda, you begin to realise that the Athena kit is still worse than a decent engine. The DT is a cracking bike for everyday use, but I wouldn't bother with much else. Zeeltronic gave the biggest improvement. Bigger carb, V-Force reed block is tempting and exhaust. That'll give your DT a really nice improvement in power, without compromising reliability. And then enjoy the 20 or so brake it gives you.
                                D Offline
                                D Offline
                                DT125Noob
                                @irongamer727 I've had casting issues with polini and malossi too. Never good fun. Usually they still need case matching and porting work. Not too bad when you can get new, performance crank cases for like a hundred quid on the little peds. Horrible if you enjoy a bike other than a moped basically. Incidentally just ordered an Athena kit to take a good look myself.
                                1973 Vespa Ciao (80 Polini Evolution RV)
                                1988 Vespa Bravo (100 Simonini side intake RV)
                                1989 Honda ZB50 (125 Takegawa dry clutch)
                                1983 RD350 YPVS 31k (TZ500 Front end and wheels)
                                1991 DT125R (French electric + kick standard)
                                1973 Honda PC50
                                  #87
                                  What would you do?
                                  Take a full refund and buy a forged piston to the original Cylinder and mount that or take another Athena cylinder?
                                  The carb is already set up for the Athena but it's not much work to set it back to stock.
                                  Could the bike be worth more with the Athena?
                                  F 1 Reply Last reply
                                    What would you do?
                                    F Offline
                                    F Offline
                                    @irongamer727 I don't think so, if it were me in the market for a bike I'd rather buy stock or close to it and do the work myself.
                                    Other people might feel differently but that's my 2p
                                    • O Offline
                                      O Offline
                                      Me, I would put back to stock and live with that, at least you know where you are with that. If you get another barrel could be more problems and no guarantee jetting would remain the same.
                                      But that's me.
                                      • Glynn123G Offline
                                        Glynn123G Offline
                                        Glynn123
                                        Would rather a standard bore than a 170 if I'm honest, get it ported and I'm doubting itd be far off the Athena. Or if you're feeling the bigger cc kits splash out for a BARacing 200kit and really feel the power 😍
                                          @glynn123 I'm so done with the big bore kits
