  3. DTRE
  4. DT 125 RE Supermoto Build
43 Posts 9 Posters 17.5k Views 1 Watching
  • Glynn123G Glynn123
    Finished caliper bracket, painted and tightened down with high tensile bolts and locktight, can finally ride the bike to test it πŸ˜ƒ
    @glynn123 love those fork skins
    Glynn123G 1 Reply Last reply
      Glynn123G Offline
      Glynn123G Offline
      Glynn123
      @declan they're really nice, think it was Β£24 for the pair and they sent an extra sleeve for between the triple clamps to add an hour meter. They're fitted by heating them up, they shrink and glue themselves onto the fork legs, a lot stronger and better held than regular stickers that's for sure.
      Also got the bike running for the first time since September and rode it around the garden after work. Felt great and brakes aren't binding so overall very happy. Engines still running sweet since the rebuild and forks feel nice, front brakes mega.
        @glynn123 a very happy you then lol glad all is well
        • Glynn123G Offline
          Glynn123G Offline
          Glynn123
          wrote on last edited by Glynn123
          Took the bike for its first test ride down a back road, feels good and everything's tight, nice and smooth and gearing feels pretty good, cruises very nice at 50mph so I'm happy with that for now. Only problem is a bit of clutch slip, gonna adjust the clutch and see what it's like on its run to the MOT place in a couple weeks, easy job if it needs plates anyway.
          Got a graphics designer making some custom graphics for the bike also, trying to keep a standard look, however update the very outdated styling.
          Headlight and windscreen also arrived from Yamaha today, sadly we have been hit with some mega snow (for Scottish Borders) and after riding in yesterday's snow I don't fancy anymore frostbite and solid fingers πŸ˜‚
          • Glynn123G Offline
            Glynn123G Offline
            Glynn123
            Well that's the build drawing to a close, light bracket made and everything wired up, Allen head bolts for forks and triples, new fork guards fitted with custom graphics, hand guards fitted, mirrors, polisport sm mudguard etc etc
            Really happy with how the bikes turned out, very minor work to go now so just the niggly bits, booking insurance tomorrow and MOT is booked for Saturday morning, sadly Scottish weathers decided to be 1 degrees on that day but should make it πŸ˜‚
            Will keep the thread updated with future changes and mods
              @glynn123 man that’s awesome well done mate
                Looking lovely bud! Love those forks as well. Look pucker great colour scheme!
                • Glynn123G Offline
                  Glynn123G Offline
                  Glynn123
                  Just a little update video, done a few little subtle mods since like front tyre etc, clocked just over 1000 miles since the build and running strong, however the cheap headgasket blew so skimmed head and replaced with Athena gasket, seems good since. think it might be time for ignitech or zeeltronic next though πŸ€”
                  https://youtu.be/WXQJr-PuTgA
                    @glynn123 I've never been able to get those cheap gaskets to work. Seriously what's the point!
                      Glynn123G Offline
                      Glynn123G Offline
                      Glynn123
                      @calum Yeah mate I know what you mean!
                      When I built the engine up I was in abit of a budget after getting a new (used) barrel, getting it bored and buying a wossner piston and so on (was at collage and worked part time at mcdonalds haha). I wasnt really aware of the headgasket problems and bought the cheap ebay gasket kit which came with one, something like Β£10 for the full engine gasket kit haha. I installed all with gasket sealant and wellseal on the head, to be fair the head gasket lasted a good few miles, but got considerably worse after the first time the engine got above 100 degrees. Ended up pressuring the coolant when ran on longer runs and stopping circulation until my temperature gauge on the radiator read over 100 degrees from the steam!!
                      Ill give wossner and yamaha their due, the piston and barrel were still immaculate, no scores and could see the honing marks like the day I got it bored after 4 boil overs and 600 odd miles. Rings werent even worn!
                      Head was warped slightly by the boils so skimmed with oil stone, 2000 grit sandpaper and a polishing compound before assembling with athena gasket and a fine coating of wellseal on each surface, I dont believe in installing gaskets without sealant. Been spot on since and hasnt lost any coolant so hoping it stays that way haha!
                        @glynn123 It shouldn't need sealant.
                        Using sealant will mask problems.
                        I've been there done that. You can use every other item out the cheap gasket set, but on these engines, either genuine or Athena head gasket is the way to go.
                          @glynn123 was it dedicated head gasket sealant?
                            Glynn123G Offline
                            Glynn123G Offline
                            Glynn123
                            @declan I used wellseal on my headgasket mate, developed by rolls Royce and used in a lot of racing engines without any gasket at all, just sealant on either surface. Top stuff and never had any trouble with it, doesn't really dry just fills minor scratches in surfaces etc
                            • 2 Offline
                              2 Offline
                              2stroketerry
                              If you get head machined flat you can get away with using a single O ring, any machine shop will cut an O ring groove cheap and use a yz O ring. 0_1525024314358_1.jpg
                              • 2 2stroketerry
                                Glynn123G Offline
                                Glynn123G Offline
                                Glynn123
                                @2stroketerry I considered doing this, however had a charity ride 2 days after my headgasket went so needed it running again for the weekend so just ordered an athena. My trials bikes always had O rings and never had a problem, if the athena gasket goes I will definetely go down the O ring route.
                                • Glynn123G Offline
                                  Glynn123G Offline
                                  Glynn123
                                  Thought it might be about time to update the post, had a brilliant summer with my dt and happy to say it's performed perfectly all year, a few minor problems but nothing major. Been quite a few little mods done since I last updated this thread, I couldn't really remember to list them but you can see for yourself haha
                                    That really looks superb. Love the forks on it. SM setup looks grand as well
                                    • F Offline
                                      F Offline
                                      That's looking sweet!
                                      What crash bungs are they?
                                      • Glynn123G Offline
                                        Glynn123G Offline
                                        Glynn123
                                        Cheers guys, they're skateboard wheels held with M8 threaded bar and nylock nuts haha
                                        N 1 Reply Last reply
                                        • F Offline
                                          F Offline
                                          Haha great idea πŸ‘Œ
