  3. Disconnect oil tank?
9 Posts 5 Posters 1.3k Views
  • B Offline
    B Offline
    Bananper
    Does anyone how to disconnect the oil tank properly? Do you recommend doing it when the bike is fullpower or will it just mess things up?
    • F Offline
      F Offline
      Do you mean get rid of the oil pump and run premix?
      B 1 Reply Last reply
        B Offline
        B Offline
        Bananper
        @finnerz89 do i need to disconnect the pump aswell?
        • F Offline
          F Offline
          You could just let it run out I guess. Why do you want to?
          • Glynn123G Offline
            Glynn123G Offline
            Glynn123
            Never heard of a Dt oil pump fail and you can adjust them for more/less oil mix so dunno why you'd want to remove it if I'm honest.
            • Glynn123G Glynn123
              B Offline
              B Offline
              Bananper
              @glynn123 alright, i've heard that they can fail. But if you say so i'd just leave it.
              Glynn123G 1 Reply Last reply
              • Irongamer727I Offline
                I run it with my 170cc Athena cylinder and it works fine
                • B Bananper
                  Glynn123G Offline
                  Glynn123G Offline
                  Glynn123
                  @bananper I considered replacing mine when I got the bike just to be safe but upon research every said they were bombproof haha, I know atleast for the past two years of regular research on DT pages and forums I've never seen someone come up with a problem. If you're really worried you could rebuild the pump, fit clear lines for the oil and bleed the system, then you'll know it's reliable and be able to monitor it.
                    @glynn123 they can fail although it is pretty rare I think they have way more positives I’d never disconnect mine I wish all bikes came with an optional oil fed system
