  4. Weird problem after oil change
38 Posts 6 Posters 5.6k Views
  • B
    B
    Bananper
    No the oil is not specially made for motorbikes, so that might be the cause?
    • B Bananper
      @bananper I’d lay my bets on it I mean you need to change it anyway so change it and if it fixes it then that’s a bonus motorbike clutches hate car oil
      • B Bananper
        @bananper if your friction plates are contaminated it might be time for new ones now I'm afraid
          @declan Not true, I use Castrol GTX 5w-30 semi synthetic engine oil on my DT no problems.
          Definitely does not like Magnetec though. Having ran that for a week or so, the clutch plates survived and went on to do many more miles.
            @calum not sure what you mean mate what am I wrong about?
              @calum fair enough. I've heard of people having to change the plates after running the wrong oil.
              You need oil that's JASO MA or MA2 spec oil, you won't go wrong with that.
              Believe or not some diesel engine oils actually meet that spec, a lot of DR650 forum members ran it in their bikes, but I never tried it.
              • B
                B
                Bananper
                @Calum @declan @finnerz89 so here's a video on whats happening. Im not sure if you can hear it, but the whole bike is vibrating, espesially the chain and the rear half of the bike
                https://youtu.be/TLG72WfwCEI
                • B
                  B
                  Bananper
                  changed to the correct oil before the video was filmed, exactly the same problem.
                  • MiniaM
                    MiniaM
                    Minia
                    The thing is we can't really see how much it is vibrating, personally I don't think it is much of a problem. All of my 2-stroke off-road bikes have vibrated, most notably my GasGas. After 10 minutes of full throttle you won't be able to feel your feet. How many miles has that engine got? If your bike is vibrating more than you believe it needs to, it would make me think the problem is a bigger one. I'd check the engine mounts, however unlikely it is.
                    B 1 Reply Last reply
                    • MiniaM Minia
                      B
                      B
                      Bananper
                      @minia around 24k, the engine has been rebuilt by an mc shop when the previous owner had it. It has never been shaking like this, just came out of nowhere
                      • B Bananper
                        @bananper If that engines been split, then they either haven't timed the engine correctly, or the clutch hasn't been assembled properly.
                        Either way easy job to fix, engine in the frame jobby.
                        • B
                          B
                          Bananper
                          @Calum @declan @finnerz89 @Minia
                          Looks like i've found the problem, only thing is that that the clutch basket is loose and i dont think its supposed to be that way
                          http://imgur.com/a/0ZTcq96
                          • B Bananper
                            @bananper The clutch basket is fastened in with a nut and a tab washer.
                              B
                              B
                              Bananper
                              @calum what torque is it supposed to have
                              • B Bananper
                                @bananper Have to check the manual I'm afraid. I'd image it's pretty high and you will need to lock off the crankshaft to do it.
                                  B
                                  B
                                  Bananper
                                  @calum i'll take the bike to my local mc shop and let them have a look on it, i think the bearing located behind the clutch bucket is bad
                                  • MiniaM
                                    MiniaM
                                    Minia
                                    @Bananper A loose clutch basket seems like a good culprit, but you need to know why it is loose. Or what made it loose. Well anyway, if you're taking it to a local shop they should be able to find and fix the problem. Afterall, the DT engine is pretty easy to work with.
                                    • B
                                      B
                                      Bananper
                                      Is the basket supposed to sit really thight or should there be some movement? It's not very loose, just a tiny bit. Do i need to split the engine to change the bearing behind the basket?
                                      • B Bananper
                                        @bananper any movement will be highly exaggerated when the engine is running don’t use the bike you will easily destroy something my 250 is about 80nm I just stuck a ratchet on there and cranked it don’t (don’t do what I do)
                                        • F
                                          Am I the only one who's noticed the chunk missing from the pressure plate? Lol
                                          I'd like the know where the missing piece went
