  4. Weird problem after oil change
38 Posts 6 Posters 4.9k Views
  • B Offline
    B Offline
    Bananper
    changed to the correct oil before the video was filmed, exactly the same problem.
    • M Offline
      M Offline
      Minia
      The thing is we can't really see how much it is vibrating, personally I don't think it is much of a problem. All of my 2-stroke off-road bikes have vibrated, most notably my GasGas. After 10 minutes of full throttle you won't be able to feel your feet. How many miles has that engine got? If your bike is vibrating more than you believe it needs to, it would make me think the problem is a bigger one. I'd check the engine mounts, however unlikely it is.
      B 1 Reply Last reply
      • M Minia
        B Offline
        B Offline
        Bananper
        @minia around 24k, the engine has been rebuilt by an mc shop when the previous owner had it. It has never been shaking like this, just came out of nowhere
        • B Bananper
          @bananper If that engines been split, then they either haven't timed the engine correctly, or the clutch hasn't been assembled properly.
          Either way easy job to fix, engine in the frame jobby.
          • B Offline
            B Offline
            Bananper
            @Calum @declan @finnerz89 @Minia
            Looks like i've found the problem, only thing is that that the clutch basket is loose and i dont think its supposed to be that way
            http://imgur.com/a/0ZTcq96
            • B Bananper
              @bananper The clutch basket is fastened in with a nut and a tab washer.
                B Offline
                B Offline
                Bananper
                @calum what torque is it supposed to have
                • B Bananper
                  @bananper Have to check the manual I'm afraid. I'd image it's pretty high and you will need to lock off the crankshaft to do it.
                    B Offline
                    B Offline
                    Bananper
                    @calum i'll take the bike to my local mc shop and let them have a look on it, i think the bearing located behind the clutch bucket is bad
                    • M Offline
                      M Offline
                      Minia
                      @Bananper A loose clutch basket seems like a good culprit, but you need to know why it is loose. Or what made it loose. Well anyway, if you're taking it to a local shop they should be able to find and fix the problem. Afterall, the DT engine is pretty easy to work with.
                      • B Offline
                        B Offline
                        Bananper
                        Is the basket supposed to sit really thight or should there be some movement? It's not very loose, just a tiny bit. Do i need to split the engine to change the bearing behind the basket?
                        • B Bananper
                          @bananper any movement will be highly exaggerated when the engine is running don’t use the bike you will easily destroy something my 250 is about 80nm I just stuck a ratchet on there and cranked it don’t (don’t do what I do)
                          • F Offline
                            F Offline
                            Am I the only one who's noticed the chunk missing from the pressure plate? Lol
                            I'd like the know where the missing piece went
                              @finnerz89 That's some beady eyes you have on you.
                              Without that, the spring won't torque down properly.
                              I can't say what real world difference that will actually make, but it might be enough to cause a problem.
                              F 1 Reply Last reply
                              • B Offline
                                B Offline
                                Bananper
                                Yup, i'm getting a new pressure plate obviously. I took the bucket of, and the axle is moving a little bit, it shouldn't move right?
                                • B Offline
                                  B Offline
                                  Bananper
                                  • B Offline
                                    B Offline
                                    Bananper
                                    #27
                                    Is this too much? It moves about 2mm
                                    https://youtu.be/3ZEvNP-LKpU
                                    • B Bananper
                                      Irongamer727I Offline
                                      @bananper that's fine
                                        F Offline
                                        F Offline
                                        @calum I'm like a hawk mate 😂
                                          B Offline
                                          B Offline
                                          Bananper
                                          @calum i am starting to suspect the balancing shaft more and more... how do i go on to check it, and time it properly?
